Ace Tone - FM-3 Fuzz Master  [schematic]
SPeter
Been thanked: 80 times
Post by SPeter »
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
That's not a gutshot.. this is a gutshot.
Sorry, this is as good I could get without removing wires.. which I've just soldered back so i can play it.. :mrgreen:
Not much to see.. a bunch of old Greenies... very cramped build.
Whoismarykelly
Post by Whoismarykelly »
Wow. That is a stuffed PCB.
Greg
Post by Greg »
Whoismarykelly wrote:Wow. That is a stuffed PCB.
Yes.. the enclosure and board size is the same as the earlier FM-2, which was a simpler circuit.. so I guess they had to cram everything onto this size board or make a new enclosure.
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
Speaking of Ace-Tone, I'm just servicing an old Ace-Tone amp......
Sickle
Post by Sickle »
A *mint* FM-2 arrived this morning before I had to leave for work!!
:twisted: :twisted: :twisted:
Greg
Post by Greg »
Sickle wrote:A *mint* FM-2 arrived this morning before I had to leave for work!!
Very nice..
Maybe you could post some gut shots of that for us ?
sidseizure
Post by sidseizure »
I thought I'd bump this thread up since I can't possibly be the only one who still wants a look at the schematic on the FM-3.
Or maybe I just need to get a life.
no you most definitely aren't! i too would like to see the little tricks talked about in this box. :D
Greg
Post by Greg »
Guys, it's traced and I've built a working copy that sounds like it should.
I just need a clear hour or two to draw up a schematic to post (I'm not too fast on the drawing)... and I haven't had it.
I'll try to get it done over the week-end.
If you take a Triangle Muff, the changes are few..
Less gain on the first stage and a 3300pf cap in parallel with the input resistor.
Lower value on the feedback caps (250pf).
Slighty different values on the tone components, but similar effect.
The volume pot is located before the last stage rather than after.
noelgrassy
Post by noelgrassy »
^ Right on! Glad to here of your success GregG. A "Triangle Muff" of all things. I look forward to seeing your schemadix. :applause:
Bernardduur
Me too!
Bernardduur
No more schematic :(
Please, post again :D
Greg
Post by Greg »
Here ya go:
Dan N
Has thanked: 58 times
Been thanked: 21 times
Post by Dan N »
Thanks for all your efforts!
So, What were the trannies?
Dick joke has expired.
Bernardduur
Thank you!
playon
Post by playon »
soulsonic wrote:Greg, could you post some gutshots of yours? All the previous photo links in these thread seem to be dead and gone.
That's one of my pet peeves about a lot of the DIY pedals forums -- tons of dead links. I go searching for something, find it, and then there is no file anymore. It would be nice to host all that stuff on some private server so it would stay around longer than several months or whatever.
Greg
Post by Greg »
Dan N wrote:Thanks for all your efforts!
2SC1000.. all caps are Greenies except the 250 and 3300pf which are ceramic.
tube-exorcist
Has thanked: 173 times
Been thanked: 67 times
Post by tube-exorcist »
Is this a "Y" on the top of the transistors ?
Greg
Post by Greg »
tube-exorcist wrote:Is this a "Y" on the top of the transistors ?
No, there's no "Y" on them tube exorcist.
