Death by Audio - Octave Clang  [traced]
DougH
Been thanked: 22 times
Post by DougH »
mictester wrote:
I saw something similar to this yesterday, but it was a homebrew job. It was an LM386 amplifier driving into a transformer, with the usual diode doubler configuration at the output.
That part of it sounds like the old "Bob Starr Octavia" or "Bobtavia" for short. The op amp recovery stuff is different though. The bobtavia sounded good driving a distorted amp or a distortion pedal. Did a good octave but not quite enough gain on its own. Maybe that's the reason for the recovery stage on the one you saw.
EDIT: Oops! Didn't see Phibes post where he already mentioned this. Sorry... :oops:
DougH
Post by DougH »
John Lyons wrote:I don't see how there can only be two resistors in the octave clang.
If it's an op amp they could be running it wide open as a comparator with the 2 resistors to set the bias. Seems like the kind of thing these guys would do.
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
I did a 386 into a PNP/NPN pair (stole it from Escobedo), and it does wicked octave:
I did a simplified version sans inductor, but it doesn't sound quite as good:
Maybe those ideas will spur some thought as to the Octave Clang's workings?
DougH
Post by DougH »
Either that or you just gave them next year's model... :mrgreen:
culturejam
Ha!
I doubt that. Mine don't have half a dozen identical mis-biased common emitter stages in series. :mrgreen: :horsey:
MicMicMan
Has thanked: 15 times
Been thanked: 9 times
Post by MicMicMan »
The IC needs to be biased either with a voltage divider on the input
not if it's a lm386
Steven_M
Has thanked: 59 times
Been thanked: 35 times
Post by Steven_M »
not if it's a lm386
You're right, but In the picture it looks like the IC is an LM741.
Solidhex
Has thanked: 10 times
Post by Solidhex »
In the last pics that John posted (the earlier model) you can get a clearer view of the IC. I have a LM741 that looks identical to the chip in the pic. Same logos etc. Also note the thickness of the pins. Pins 2,3,6, and 7 are all way thicker than the others. The LM386's I've seen don't have that. That early model is even stranger as there's only one resistor visible! It has a red LED though. I can't tell if its a mistake the way they wired the output control on that one. Its wired as a variable resistor to ground instead of a voltage divider. Not very effective as a volume control. They corrected this in the later version.
doug deeper
Been thanked: 101 times
Post by doug deeper »
i have a hunch there are some resistors on the back of the board.
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
That's a point, there could be a full compliment of 1206s on the back.
Steven_M
Post by Steven_M »
doug deeper wrote:i have a hunch there are some resistors on the back of the board.
That could be true, but I dont understand why you would go to the effort to make such a nice board like that (Three different versions from what I can tell) and on every revision leave the resistors under the board.
Maybe it's to throw off chancers like us!
Hides-His-Eyes
SMT resistors on the underside saves drilling and leads to neater layouts.
Steven_M
Post by Steven_M »
I really doubt these guys are doing anything SMT. But, stranger things have happened at sea!
Hides-His-Eyes
True enough; I mean, having seen how far their game has been stepped up from that other pedal that was shown in here, I don't think anything they could do would surprise me...
s.koma
Post by s.koma »
i actually built one of these, using a 386.
it has all of the trademarks: horrible sound & ridiculously high output volume. i sure liked that :)
thus... it might be one. also, if you buy bulks of 386s directly from asia, their looks can vary a lot.
just my 2ct...
Glass_Hero
my favorite amplifier: My Glass Hero Amplification
Completed builds: 1973 Orange Graphic 120 head
Fender Champ clone head
custom Pentode input single channel 20 watt head
custom "plexi" 5 watt single ended head
custom Pentode input single channel ~2 watt combo (smaller version of my 20watt)
( i build amps and pedals )
pedal clones
Pro Co Rat
Univox SuperFuzz
Sonic Edge J&J Overdrive
Interfax Harmonic Percolator
EHX Electric Mistress
EHX Big Muff PI
EHX Big Muff into a DBA Fuzz War
Green Ringer
Orange Squeeze
Boss Slow Gear
Death By Audio Sound SAW
Death By Audio Armageddon
Death By Audio Fuzz War
MXR Phase 90
EA Tremolo
TS 808
another TS808 modded out for bass
various loop, boost, kill, stutter, feedback and signal pad stompboxes
pedal modds
big muff clipping modds and internal feedback loops w/ LDRs
EHX POG exp pedal modd
VOX 847 wah modds (expression pedals should be expressive)
Cry Baby Modds
BOSS XT-2 modds
this list is tragically outdated..
Been thanked: 116 times
Post by Glass_Hero »
this looks like it could be it...
Can this work with a 741?
and could the 'tone' control be a pot between the offset nulls on the IC chip?
Bobs Octavia.bmp (19.19 KiB) Viewed 4706 times
Seven64
Been thanked: 7 times
Post by Seven64 »
can anyone confirm/deny this layout? sorry to revive from the dead
Glass_Hero
pedal clones
Pro Co Rat
Univox SuperFuzz
EHX Big Muff PI
Green Ringer
Orange Squeeze
Boss Slow Gear
MXR Phase 90
EA Tremolo
TS 808
pedal modds
Cry Baby Modds
BOSS XT-2 modds
i'm bringing this back from the dead because i have a schem for this.. i got to peak inside an octave clang the other day and it only took about 25 mins to come up with this..
Its much like a bobtavia.. the transformer is a 2k secondary and 10k primary..and you drive the secondary and take the out from the primary.. the input filter is much like the supersonic fuzz gun density control.. pin 5 is grounded, this is part of the null offset on the lm741.. pins 1,3,8 are left open.. i did not add the switching or LED in the schematic..
davidnaas
Post by davidnaas »
Glass_Hero wrote:i'm bringing this back from the dead because i have a schem for this.. i got to peak inside an octave clang the other day and it only took about 25 mins to come up with this..
Just great! This will be my next build, just a couple of questions....
1. Is this scheme sure to work?
2. What hapens if you switch the values of the transformer? Seems quite hard to find the exact values in my part of the world. Also is the middle-left leg of the transformer left open?
3.Is the symbol at pin 7 only the 9 V DC input? And which pin is pin 8?
earthtonesaudio
Been thanked: 75 times
Post by earthtonesaudio »
Op-amp abuse! *cringe*
