the schem came from tracing the actual pedal..davidnaas wrote:
Just great! This will be my next build, just a couple of questions....
1. Is this scheme sure to work?
2. What hapens if you switch the values of the transformer? Seems quite hard to find the exact values in my part of the world. Also is the middle-left leg of the transformer left open?
3.Is the symbol at pin 7 only the 9 V DC input? And which pin is pin 8?
the transformer is available from mouser 42tm002 or the 42tl002..digikey has a more expensive version..i'm not sure what the difference would be if you changed to a different part.. in the mouser catalog this transformer is listed as a driver, all the other ones are either coupling, interstage, or output..
pin 7 is the 9volt connection.. pin 8 is NC and left open.. the chip is an LM741..look at its datasheet for more details on this..
