0.39μf Caps. Where in the world?
camsna
Post by camsna »
Can't find them just about anywhere. I ordered some from Futurlec, but they ended up being out of stock with no expected stock date. I have EVERY other value I need, but for the life of me can't find 0.39μf.
Any recommendations?
Thanks again!
Cam
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
camsna wrote:Can't find them just about anywhere. I ordered some from Futurlec, but they ended up being out of stock with no expected stock date. I have EVERY other value I need, but for the life of me can't find 0.39μf.
Thanks again!
Cam
Use 330n and 68n in parallel - it'll be close enough. That's 0.33µF and 0.068µf for you non-Europeans.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Thanks again!
Cam
You could also try using a .47uF cap instead,capacitors usually have a tolerance of + and - 10% of the marked value.... :)
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
Futurlec
LucifersTrip
my favorite amplifier: Companion Psychedelic Machine
Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
Has thanked: 19 times
Been thanked: 70 times
Post by LucifersTrip »
Thanks again!
Cam
If you don't have 0.33µF and 0.068µf (since they're less common), you can use .47uf & 2.2uf in series
...and there's many other combos. Just check thru your stock and:
http://www.kusashi.com/series-capacitors.php
good luck
Has thanked: 218 times
Been thanked: 857 times
Maestro parametric filter clone ? :secret:
