How can I increase the volume output in my dirt pedal?
sleepykitty
Post by sleepykitty »
Recently built a crunchbox clone. Is there any way to increase the output volume? Can I put a larger pot value in to do this? thanks
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
Ehm, no, increasing the potvalue won't do much
Add a small booster at the end
playon
Post by playon »
What would it take to increase the output of the Ross D? Different volume pot value?
playon wrote:What would it take to increase the output of the Ross D? Different volume pot value?
Volume pot value doesn´t change anything.... you need an extra gain stage.... if it is the dual op-amp version this shouldn´t be a big problem....
dv8
Post by dv8 »
You can change out the clipping diodes and put in leds, that always gives a little boost.
-brian
