PNP MKII Wiring problem
OnTheTundra
Post by OnTheTundra »
I asked for this before but forgot to save the file, but can someone please post the wiring diagram for a PNP positive ground fuzz? The last time I asked somebody posted the diagram from GGG and I went back to look for it there and couldnt find it. So if you would be so kind...
I promise to save it on my computer this time!
Also Im building the Tonepad MKII Fuzz so maybe someone has a wiring diagram for that too.
THANKS
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
OnTheTundra wrote:I asked for this before but forgot to save the file, but can someone please post the wiring diagram for a PNP positive ground fuzz? The last time I asked somebody posted the diagram from GGG and I went back to look for it there and couldnt find it. So if you would be so kind...
THANKS
I'll just draw up a diagram for you and post it here.... :)
I'm assuming that you mean the Tonebender Professional Mk II
Post by DrNomis »
Here you go,hope this helps,let me know if you have any trouble with your build.... :)
Note that the red wire from the battery clip is the positive lead,and is soldered to the ring connection on the input socket,the tip connection is connected to the footswitch.... :)
The black wire from the battery clip is the negative lead.... :)
MkII Positive Ground Wiring
I think this is what he is looking for. :wink:
http://www.generalguitargadgets.com/dia ... a841b3e85a
Post by DrNomis »
RnFR wrote:I think this is what he is looking for. :wink:
RnFR,I know that this is a bit off topic,but I was wondering where does your User Name come from?,hope you don't mind me asking... :)
Thanks in advance.... :)
spookybonus
Post by spookybonus »
i am going to take a guess: Rock n F*cking Roll?
OnTheTundra
Hey do you guys know how to add a voltage sag to a positive ground pedal? I can do it negative ground no problem (the beavis wiring) but Im wondering if I should put the same wires in the pot or if its just depends on the purpose of the wire. Thanks
spookybonus wrote:i am going to take a guess: Rock n F*cking Roll?
Give that man a prize. [smilie=a_partyguy.gif]
OnTheTundra wrote:Hey do you guys know how to add a voltage sag to a positive ground pedal? I can do it negative ground no problem (the beavis wiring) but Im wondering if I should put the same wires in the pot or if its just depends on the purpose of the wire. Thanks
Same exact way you would do it on a neg gr pedal.
spookybonus
wooooohoo! i'll accept a stash of germanium transistors for my prize! haha
