schematic to veroboard newbie
aelling84
Post by aelling84 »
Hi everyone,
I´m still new to the whole reading schematic and getting them on veroboard thing(y), so I was just wondering if this veroboard layout is correct or not.
It´s for the GGG Shin-Ei FY-2 schematic WITH THE BOOST ADDED, which you can find here.
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
I haven't checked your layout, but there are a few things I noticed:
you have resistors going to adjacent tracks. That's OK, but you'll have to stand them up, which will make your board taller. You also have angled components - again, this is OK, but often can take more room than it they're all in the same orientation. I'll have a go at an FY2 Vero layout and see if I can get it small and neat.
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Not standard practice but if like on your layout you've got space above and below what would be a standing resistor, I personally fold the leads back under the resistor and into the holes (form it before you put it in) so that the resistor itself takes up more space but the wires themselves are only one track apart.
Another personal preference for me is to always put electrolytics in empty spaces if possible so I can lie them down, although that might be unneccessary depending on what capacitors you use (no point making things shorter than the tallest component)
