Does anyone here have a source for those little green Alpha pots that are PC mounting? Is there a reason you folks may not like using them? I thought about standardizing my FX builds and that was the first idea I wanted to persue.I know that they'll get abused but if stabilized [see Mackie mixers] correctly why couldn't they survive? Doesn't Cusack use a board mounted pot? His gear seams roadworthy to say the least. TIA, NGHave a source for Alpha PC mount pots?
- noelgrassy
- my favorite amplifier: MOTS Magnatone & Trainwreck
- Completed builds: Tonebender Mk II w/ 3 OC75's, Burns BuzzAround w/NKT 275,Rangemaster w/ OC44, Fuzz Face w/ SKS363's, CJOD, Harmonic Percolator w/2N404A & 2N3635(vintage correct box,sliding pots, 1%glass resistors),Stack-O-Dimes & Whipple Wahs,
- Has thanked: 11 times
- Been thanked: 3 times
Does anyone here have a source for those little green Alpha pots that are PC mounting? Is there a reason you folks may not like using them? I thought about standardizing my FX builds and that was the first idea I wanted to persue.I know that they'll get abused but if stabilized [see Mackie mixers] correctly why couldn't they survive? Doesn't Cusack use a board mounted pot? His gear seams roadworthy to say the least. TIA, NGCopyright does not protect facts, ideas, systems, or methods of operation, although it may protect the way these things are expressed. US Copyright Office
- Dirk_Hendrik
Ive said it, and I'll say it again.
From a functionality perspective (service/repair can be tougher) there's nothing wring with board mounted controls, jacks switches etc, u]Provided [/u]that they have a proper mechanical strain relief.
- noelgrassy
Cool, thanks you guys. I guess I didn't look closely at Small Bear's site. The pots at mouser don't appear to have the splined metal shaft. I'll dig into your suggestions a little deeper. NG
