1M Reverse Audio 24mm PC Pot
- Crumbchildz
I've got one of the older Memory Man units (1xMN3005, 1xCD4047BCN, 1xNE5554N, 2xRC4558, 1xMC1458) and I'm looking to find a replacement DELAY pot. It's a 24mm 1M Rev Audio with right-angle PC pins. I'd be very OK with a pot with solder terms, but I can't even find one of those! Any help would be a big help! Thanks.
Loud's a tone, right?
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
effectsconnection have 16mm.. is the shaft diameter different?
- Crumbchildz
I believe so....but worst case scenario, I could make a 16mm work.
