[Stripboard] VOX McCoy
Here's my second take with stripboard layouts ever, so be carefull with this one. Handy person could point me mistakes if any.
Enjoy
Pinout for popular wah trannies are wrong side. It's ok, since no body really give a fuck :mrgreen: I don't think I'll bother to post my layouts anymore
mcaviel
Has thanked: 70 times
Post by mcaviel »
Hey i give a F$%#, post the schematic you worked with if you need another pair of eyes.
Duckman
Has thanked: 320 times
Post by Duckman »
sinner wrote:It's ok, since no body really give a fuck :mrgreen: I don't think I'll bother to post my layouts anymore
Everybody is very sensitive, lately :mrgreen:
the3secondrule
Completed builds: GGG Phase45
Fuzz Factory Clone
Shin Ei Companion Fuzz
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
Has thanked: 24 times
Been thanked: 13 times
Post by the3secondrule »
This is pefect timing since I just scored 3 crybaby shells - Thank Sinner :thumbsup
yeah, post your schem and I'll have a look as well. although i'm still pretty n00b when it come to tracing stuff out :D
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
I'm sorry guys, I had really shitty mood yesterday. I guess it's the way to go for me to be monkey on the net recently... :( Gimme a time, and I'll post corrected layout + all sort of variation as a part of apologizes
As i said 8)
the3secondrule
Fuzz Factory Clone
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
cooooooooool.
:D
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Don't be a monkey!
Image Ken
Layout is wrong! Will correct it later on
the3secondrule
Fuzz Factory Clone
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
layout looks pretty good to me against the schem here: http://fuzzcentral.ssguitar.com/mccoy.php
of course, i'm a muppet so I could be wrong :slap:
Any progress sinner? gonna take a couple days off work this week to toy around with wah pedals
Chceck the trace cut below 1k resistor. It should be one line below. After that this should rock. The reason why it takes so long is - I'm doing several layouts at the same time :D Also I wanted to add another vero wah with some mods like the sweep and SPeter's tone idea to replace the range cap selector
Ok, here's the twicked thing. I've added sweep pot - value listed is 100k lin, but you can try 50k, or use jumper in place of 33k resistor and go with 100k pot with push-pull on-off switch to mimic Grey wah. Range control is the idea I've found in DAM Red Rooster tread posted by SPeter. Another higher value cap is blended in to standard 0,01uf cap. In CW position the value is close to 0,068uf - typically for bass wahwah's, in CCW is we have standard Clyde McCoy resistance. It's the same thing that selected range used in wah's like Fulltone's Clyde Deluxe, but in place of 3way selector control knob is used. You can try other values, like lower one for the main cap, and bit higher for the blend-in, but theoretically this is optimum. Layout is not verified. Let me know what you think, and if you spot mistakes
Any idea what else I can put in here? ;) Wah wah enclosure is big, let's go wild :mrgreen:
hewie
Has thanked: 20 times
Been thanked: 46 times
Post by hewie »
Maybe a switchable buffer circuit? The modded layout looks great as it is though, I'm thinking about wiring one up today. Cheers!
Please update the file to this. One missing trace cut and none sense was fixed thanks to circuitworkshop.com member
Ok, apparently I was on high drawing previous modded layout, here's corrected one, I took a lot of care making sure it will swing!
BOM match RG.Keen wah article. Few things added - 1. pulldown resistors, 2. LED status on 3PDT, 3. power filtering.
Rq is omitted on board, use 100k sweep control to shift value from 0ohm to 100k and use push-pull or on/off switch to omit it completely to mimic Grey Wah spec
Maleco
Post by Maleco »
Since my Crybaby died, i wanted to use the shell to buil my own clone and was thinking about the colorsound wah.
It's going to be used for humbuckers playing some hardrock/metal stuff. You think the colorsound is capable of doing this?
I don't have the ability to make my PCB so it has to be Vero or Perfboard.
Oh and can i re-use the original crybaby inductor for this?
No idea about the HB stuff buddy. AFAIK Timm aka Phibs is working on Colorsound Wah, he may be more helpful
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
What inductors are you using Pawel? I've got a 535Q but I quite fancy making one of these to go in an old Crybaby case I've got somewhere.
