Hi Everyone,
Interesting discussion, I love dispelling all the myths that 'experts' have tried to create around the electric guitar. I'm a physicist/RF engineer (I build things for MRI scanners), and it's been really interesting coming back to the guitar with the knowledge I've learnt about RF electronics. I'm repeating what's already been said here, but maybe some of you would appreciate the second opinion.
Most pickups have shielded cables, which should be connected to ground. So there will be no capacitive effect between any cavity shielding (such as copper/aluminium foil) and shielded pickup cables. For unshielded cables there will be an effect, google wire above a ground plane for the answer. It's not likely to be a large effect, shielded cable connecting the guitar to whatever comes next is likely to add a lot more capacitance. For pickups, there is some capacitance between the windings, and if the pickups are shielded then there will be some capacitance there. Apparently shielded pickups are less bright than unshielded, which would make sense (I've never tried them it on the same guitar so I can't comment).
There was a mention of ground loops:
dai h. wrote:re: star grounding (from the quote) (not my original observation, but) I would think the currents inside the gtr. are typically so miniscule that there would not be much point in star grounding (no significantly higher current loops which carry signal that could be superimposed over more sensitive loops via the common ground line to put voltages where they should not be and cause problems such as hum, oscillation).
You definitely want to star ground your guitar. Any loop will act as a small antennae that will pick up the 50/60Hz electromagnetic field from the electric wiring in your house/studio/stage etc. 50Hz has a wavelength of around 6000km, and so you're definitely within the near field regime unless you are in the middle of the Pacific Ocean. Any loop of wire will couple strongly to this field (it's mostly magnetic), this includes a loop in your wiring in your guitar, this causes a common mode signal down what should be a differential (ie single ended) mode and that's why you hear a ground loop. I always star ground my guitars, it makes a hell of a difference.
Oh and how to tell the difference between a ground loop and single coil noise. Single coils pick up the mains frequency from lighting etc, however it tends to be the higher harmonics (100/120Hz+) and so sounds more crackly and thin. Ground loops are predominantly at the fundamental mains frequency and so are very much a low hum.
