Danelectro - DD-1 Fab Tone Distortion [schematic]
- briggs
Clay - on another point, do you have the scheme for the tone section of the danelectro fab red distortion (the one with the active mids section), I've been interested in that section of the pedal for a while now but I've, as yet, been unable to locate a single scheme for it!
EDIT: schematic found, threads merged!
- Uma Floresta
You mean this one?
Clay drew this out a while ago. No values, though. The SMD resistors have the values printed on them, but the SMD cap values, where printed, are a mystery to me - sames goes for the SMD trannies.
- briggs
- Uma Floresta
I could maybe try to fill in some of the blanks - I'm in the middle of studying for the GMAT, but if I can find some time I'll see about getting some of the R values, at least.briggs wrote:Hmm, I wish I had some values. I'd love to do some work and have a look at what frequency bands that tone section is working at!
Anyone got values?
- briggs
- Uma Floresta
Actually, I might be able to get cap values too - some of them are regular size film caps - we'll see!
- jakerandall
Is that the full schematic for the daneletro red fab distortion?
Anyone have any values yet?
- Uma Floresta
Shoot, I'll see if I can post some tomorrow - I've been so busy.
- Uma Floresta
Okay, here is what I was able to do today:
Opamp is a tiny LM833. I'm sure I got some resistor values wrong - some of them were very hard to read. The values are in small print, and some of them weren't printed very well. I will compare to my other Fab Distortion to see if I those particular resistors are printed better.
The caps that I marked "? pF" are completely blank. They look much like the SMD resistors, but have no numbers, and are kind of foggy in the middle. I assume they are low value. The other two mystery caps I filled in here had clear markings, but I have no idea what value they might be, and my multimeter doesn't measure capacitance. I have no idea what the transistor is, either.
Eventually I'll see if I can flesh out the whole thing, or as much as possible, after the new year.
- Uma Floresta
Okay, I actually was able to finish getting values for everything - but I am sure there are errors in some places. After new year's I'll sit down with a magnifying glass and really look closely. My eyes hurt after this exercise.
- briggs
- Uma Floresta
No problem!briggs wrote:Many thanks Uma. I've been after investigating this one for a long while now!
- Uma Floresta
I wasn't planning on doing any more, but I had the nagging feeling I'd got something wrong, and so I did.
I think I've figured out the values on the marked SMD caps - AA7 is 10uF according to a data sheet I found, and E105L is so obvious I missed it - 1uF. The letters threw me off the otherwise normal capacitor code convention.
I still don't know what the transistors are. The diodes are marked as being 1.9v.
I'll put this on my list of things to build. This really is a great little pedal, and using some quality parts and perhaps tweaking it a bit might make it even better.
- Uma Floresta
Clay, if you're around and you see I've made any more errors, please point them out!
- Uma Floresta
According to this site:
http://www.digchip.com/datasheets/parts ... s_ks08.php
L7 could be an NPN Epitaxial Silicon Transistor: 40v, 100ma.
If that's the case, perhaps the following transistors could be used in a non-SMD build:
2N3903
2N3904 - available at Small Bear
MPS3904
I don't know a lot about transistors, someone tell me if I'm off. All of these are supposed to be NPN, 40v, 100ma
2N3903
MPS3904
For L7 you can use any high gain trannie, like 2N5088 or BC549C.
Take a look on Boss or DOD schems for HM-pedals. Those pedals have similar gyrators and the trannie specs are on the schems too.
You can even subs the trannies with a LM833 or other dual opamp, IBZ pedals often have IC-driven gyros.
JHS
JHS
- Uma Floresta
Yeah, it does look similar. Good eye!swt wrote:that looks similar to the nobels od1r, although i guess the nobels sounds better, clearer and od focused...
- briggs
- jakerandall
Briggs lets see your build.
I am playing with this. I am thinking it might need the buffers. There are still some missing values. I wonder if there is a different chip that could be used as well.
