Connecting ac socket and a transformer
Locked
kin0
Post by kin0 »
hay I don't know how to connect this part:
Uploaded with ImageShack.us
any help?
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
You don't know how to do it physically or don't know where to connect it?
kin0
Post by kin0 »
Where to connect (my transformer got 5 wires and the one in the schematic 4, also the same with the socket, mine is different than the schematic).
Duckman
Has thanked: 320 times
Post by Duckman »
If the 3 cables are your input, you got the option to feed it with 110v or 220v (cable 1 + cable2 = 110v; cable 1 + cable 3 = 220v) If the 3 cables are your output, then you got a central tap, useful when you need a dual voltage configuration, like +9v / -9v and central tap goes to ground.
Any way, verify this before connect any thing (I think I'm missing something)
Duckman
Post by Duckman »
kin0
Post by kin0 »
Oh I know found that it is written
Black-PRI 220V 50Hz
Red-SEC 6VAC X2 1A
GREY-C.T
so are the black one the input, the red ones once are the output and the grey is ground?
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
kin0 wrote:Oh I know found that it is written
Black-PRI 220V 50Hz
Red-SEC 6VAC X2 1A
GREY-C.T
The black ones are the incoming mains supply - correct.
The connection to the output leads depends on the AC voltage you want - your circuit calls for 12V AC, so use the two red wires, and don't connect the grey wire to anything - just insulate the end of it so that it can't touch anything.
kin0
Post by kin0 »
Oh. My transformer is 2x6v. Can I get more than 12v (about 16?)
kin0
Post by kin0 »
btw can I run a shredmaster with 12v?
Locked
