Free ID-Mark Samples
snmavronis
Completed builds: My DIY stompbox builds:
- Neo-Classic 741 Overdrive (gray spec 250 Overdrive clone)
- MXR Distortion+ (diy replica pcb replacement 1980 block logo)
- Neo-Classic 3080 Compressor (script spec Dyna Comp clone)
Been thanked: 14 times
Post by snmavronis »
Today in the mail I got my free samples from Horizons Imaging Systems Group:
Here is what they sent me:
ID-Mark unprocessed plates 5"x6" black .007" aluminum 4 sheets total
ID-Mark unprocessed plates 5"x6" red, black, blue plastic 2 sheets each color (I wasn't expecting this)
CD with Apple Quicktime video about how to make your own signs, labels, decals, plaques and awards, and panel fronts
I've used the aluminum plates before as the top of my pedal clone for graphics and labeling. ID-MARK - Photopolymer Resist Coated Aluminum and Polyester Sheets with Adhesive Backing
http://www.horizonsisg.com/idmark/idmar ... ester.html
They come out real professional looking and better than tricky decal application (unless you are good at that) but you can make several pedals with these free offerings. Anyway you can request free samples from this page: http://www.horizonsisg.com/durable-subs ... mples.html
Guitar > Boss NS2 Noise Suppressor > NS2 Send > MXR Custom Comp > Neo-Classic 741 Overdrive > NS2 Return/Output > VHT Special 6 Ultra Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
I asked for samples some time back but received nothing.. I guess they figure out of country is too hard..
mikemaddux
Post by mikemaddux »
sorry to sound ignorant....can these be etched with ferric or do they have to be done with UV?
snmavronis
They are UV light exposed with your labeling graphic and etched away with ordinary water!
ID-MARK sheets are photopolymer resist coated sheets of aluminum and polyester. The resist cures when exposed to UV light and rinses away with simple tap water in the unexposed areas, leaving behind spot color graphic images. The process is as follows:
1.Create artwork using any software
2.Print film through which the ID-MARK sheet will be exposed
3.Expose sheet to UV light in a suitable exposure device
4.Rinse or Develop sheet with water
5.Dry sheet
Here's a graphic from their page (http://www.horizonsisg.com/idmark/the-i ... ocess.html) illustrating the process:
Greg_G - There is also a UK company Dantech (http://www.idmark.com/idmark) who sells ID-Mark sheets. But you being in Australia this probably doesn't help your shipping situation.
mikemaddux
sounds interesting, thanks for clearing that up....
