Help with 3-way Mini DPDT
kinski
Has thanked: 10 times
Post by kinski »
I just built a Bazz Fuss. Awesome!
I'd like to add two 3-way mini dpdt switches. One to select 3 different input caps, and another to select 3 different transistors.
Problem is...I don't know how to wire the mini switches up. The switches have 6 lugs. Won't I need all 6 lugs just for the "legs" of the caps or transistors?
Any help would be greatly appreciated. Thanks!
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
If you look at this layout for the Vorpal Fuzz, that shows how you'd do with with the caps (even though they're resistors in that layout).
You need to connect the wires to the centre two lugs which are the switch commons. If you then also put a cap between those two lugs then that will be always in circuit. Then put two caps between the other lugs on either side as shown in the layout.
Bear in mind that you can't switch between 3 cap values, the centre one will always be in circuit. So then adding the caps on each side in parallel with the main cap adds the values. So if you had a 10nF in the centre position, another 10nF on one side and 47nF on the other, you'd get the equivalent of 10nF in the centre off position, 20nF in one position and 57nF in the other.
You would only be able to switch between two transistors, just take a wire from the emitter and collector positions on the board and take them to the centre two lugs. Then attached the emitters and collectors of the two transistors to the appropriate side of the switch. The bases are just commoned together and connected to the base pad on the board.
kinski
Post by kinski »
Hey, thanks a lot. This is the exact info I needed. I know what I'll do with the caps.
But, the transistors....basically, if I only use 2 transistors on the switch, the middle switch will have no transistor, right? I'd prefer to not have one position with no transistor. I have a pedal built by someone else, and it allow for 3 different transistor to be selected, and its on a 3 way switch...is there a different switch that i should be using to do this?
YuGi
Been thanked: 25 times
Post by YuGi »
kinski wrote:Hey, thanks a lot. This is the exact info I needed. I know what I'll do with the caps.
Yea you can use a on-on-on toggle switch or a rotary switch.
kinski
Post by kinski »
yeah, i have a on-on-on switch. sorry if i was unclear.
its an on-on-on switch with 6 lugs.....what do you think?
YuGi
Post by YuGi »
I mean on-on-on with 4 lugs (or 8 if double).
Like this http://www.musikding.de/product_info.ph ... -DP3T.html or a rotary like thishttp://www.musikding.de/product_info.ph ... d-pcb.html
kinski
Post by kinski »
YuGi
Post by YuGi »
kinski wrote:ok...so this won't work:
http://www.ioffer.com/img/item/167/351/851/8oJu.jpg
IvIark have well explained what you can obtain with this kind of switch (that probably is an on-off-on).
kinski
Post by kinski »
What I have is an ON-ON-ON. It says so on the side. Yugi mentioned I could do what I'm trying to do with an ON ON ON switch...but how would I wire this? Is the layout he posted an ON ON ON, or something else?
lietuvis
Has thanked: 95 times
Been thanked: 83 times
Post by lietuvis »
for this kind switch on on on look at bartolini preamp wiring diagram, midrange frequency selection.from there you might figure out possible ways for wiring.
lietuvis
Post by lietuvis »
see if this help you with cap wiring, swapping transistors will not work with this switch.
kinski
Post by kinski »
hmmm...okay...so, is there a toggle switch that will allow me to do this?
lietuvis
Post by lietuvis »
kinski wrote:hmmm...okay...so, is there a toggle switch that will allow me to do this?
yes you can do it with ON ON switch and toggle between 2 transistors, to toggle 3 I have not seen that kind of switch to be toggle,rotary(bigger)-yes.
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Liet that one's for a Z switch isn't it?
lietuvis
Post by lietuvis »
Hides-His-Eyes wrote:Liet that one's for a Z switch isn't it?
Z switch ? I don't know what Z switch is. I Just tried to help with on/on/on toggle switch,to which recently I was wiring to my unsuccessfull copy of bartolini ntmb preamp (where I believe that schematic floating on net is incorrect,I had chance to take some measurements from working unit and they did not matched schematic values)
kinski
Post by kinski »
Okay, thanks everyone for your replies.
I'll give up on the 3-way transistor selector. I like the one i have in there now anyway.
however, I would like to do the 2-way input cap selector.
Please bear with me here. I'm totally new at building pedals...
1. How would I wire up a 2-way toggle switch (ON-ON, right?) to choose between 2 different input caps.
2. I really like the stock cap of 4.7uf. I'd like another cap that would cut the bass. Would 2.2 be a good value, or does anyone else have a suggestion for a 2nd cap option?
Thanks again for your patience and help!
YuGi
Post by YuGi »
Yea try 2.2 for bass cut first, anyway you can try other values if you don't like it.
kinski
Post by kinski »
Awesome! That's what I needed. This forum is incredibly helpful. Much appreciated, everyone. :thumbsup
kinski
Post by kinski »
Okay, I wired the switch up. Easy enough. The thing is...I can't hear ANY difference between the 4.7uf and the 2.2uf or even a 1uf. What's the deal? I check the - and + and everything looks fine. Eh?
YuGi
Post by YuGi »
What is the schematic?
Anyway maybe you have to decrease even more the capacitor to hear the difference.
