Devi Ever Ruby
Akridosity
Post by Akridosity »
I don't know know if this is against the forum rules but, does anyone have any info/schematics on the Devi Ever Ruby. It has a really interesting tone and I'd love to have one.
EDIT: I've found a gutshot of the pedal, though the switch is no stock.
Steven_M
Has thanked: 59 times
Been thanked: 35 times
Post by Steven_M »
Looks like two boosters in the lineage of this stuff:
http://www.etsy.com/listing/50620272/pl-sc-db-kp
teej212
Been thanked: 8 times
Post by teej212 »
from devi ever:
For the Ruby, it's the same pot post-circuit, with the 05 there, and then the second circuit in the normal position is an 05, but using 104 capacitors instead.
If you want a darker version of the Ruby, have the second PCB be a Dark Boost.
goes Gain Pot (input volume control)-> 05 with .01uf caps ->05 with .1uf caps-> Volume control
heres the 05 schem
Akridosity
Thanks for the info teej.
What transistor is used though?
Akridosity
Nevermind, an MPSA18 is used.
I'll do a quick breadboard test and share results, might have to do this over the weekend though.
Thanks guys.
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
Devi posted a schematic with 2 transistors so this must be the updated version:
Devi Ever Ruby.png (23.31 KiB) Viewed 1144 times
