Colorsound - Power Boost / Overdriver
- freedreamer
hi ,
anyone has schematic and/PCB of this pedal?
thanks for the help
thanks for the help
- analogguru
As far as I know it should be (nearly?) identical to the Colorsound Overdriver
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
http://homepage.ntlworld.com/s.castledi ... erdrv.html
This page contains schematic, pcb files and parts layout for the overdriver and confirms: "The Overdriver was introduced in the early '70s. I believe it was originally sold under the name "Power Boost".
[/img]
[/img]
- Goop_buster
This booster is a highly recomended build.
Check out Arons forum for additional info about some minor errors or if it was wrong component values in the schematic (if I remember right).
Back in the days people like Jeff Beck and Jan Akkerman used this booster
Akkerman - >
Do not let the sloppy beginning fool you. This guy play some amazing stuff and absolutely tears up the guitar neck ...for being 1973
Akkerman - >
- analogguru
really awful how they mixed up the capacitors in the tone-control section. If there woudn´t be the picture I wouldn´t believe it.
Bernardduur: My '96 Colorsound Overdriver wrote:So
This was the first pedal I ever bought; I was on a vacation in England and ventured into Sola Sound shop, somewhere in London. I had to choose between the Tonebender and this box; you know which one I chose. It has been on my board now for years and years...... Awesome pedal!
Old schematic which can be found on the internet
Same schematic but now with altered values for my '96 unit
Transistors are BC184L's. The only thing missing from the schematic is the 1M to ground pull down resistor and the 100k volume potmeter
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
Notice those nice quality HIGH VOLTAGE capacitors for nice tone
I have 3 different schems of the old OD (early years) and maybe C-sound made even more variations on the original circuit. C-sound used different trannies in the '70-ties and always modified parts in the circuit to adapt different trannies. IMHO they have done the same thing on the '96-model or at least some improvements. Soundwise there will be no or only a slight variation in tone compared to the old units.
2x100n caps + a 10k pot on the treble control is OK, old units have 2x10n caps + a 100k pot. The frequency curve for both combinations is equal.
Often due to dried out or weak electrolytic caps most old C-sound ODs sound muddy and after a re-cap those ODs sound like the should. Replacing those coupling caps with metal film caps like on the '96 is a very good upgrade and 470n is OK. Electrolytic coupling caps are often chosen 10 times bigger than there metal film counterparts to compensate the heavy bass-frequency losses electrolytics are known for.
JHS
JHS
- Bernardduur
She sounds pretty good, although the gain control doesn't do much until it is at 75% or so....... then the unit becomes gritty and fuzzy
I use it mainly with the gain at 0 boosting the amp; it has a lot of volume!
- Bernardduur
Underside to complete the picture; notice the marking "Powerboost 96"
- analogguru
Hey cool, thanks !
The Akkerman sloppiness at the beginning is totally intentional. The 'broken' beginning eventually became the trademark of Hocus Pocus live.
Akkerman is quite the eccentric guy. Back in the day he loved Les Pauls but couldn't stand how little treble they produced. He was always on about how important it was to get the most treble possible in his sound.... I remember reading interview after interview of the guy spelling out his recipes for guitar sound as if it was gospel.
But yeah, a monster on the neck for sure. What a great song that was.
- MoreCowbell
JimiB wrote:what trannys are those?
Bernardduur wrote:Transistors are BC184L's.
- Bernardduur
Your not blind; I think I missed itpf_fan wrote:This schematic of '96 Colorsound Power Boost shows two 22uF capacitors. When I looked at PCB shot I noticed three 22uF caps. Is something wrong with the schematic or am I blind?
Thanks. Is it this one?Bernardduur wrote:Your not blind; I think I missed it. The cap is placed between the V+ and ground
I think that I noticed one more thing. I counted 15 resistors on PCB. Schematic have only 14. To make things more complicated I found another picture of the PCB which has... 16 resistors! I circled this additional one
I have Prescription's version of the Overdriver and it uses 2N3904's rather than BC types. BC184C's I have are much higher gain than 3904's I have. Should there be a great deal of difference in sound between the two types in this circuit?
- Bernardduur
I'll check it tonight!pf_fan wrote:Thanks. Is it this one?Bernardduur wrote:Your not blind; I think I missed it. The cap is placed between the V+ and ground
