Colorsound - Power Boost / Overdriver
- clintrubber
Thanks for the pics'n'files!
Bye
Won't make much difference, the involved caps are DC-blocking, not toneshaping. The 12k is already 'DC-less' because of the caps @ its other side.cpm wrote:Notice the connection of that 12k feedback resistor now it goes right into the gain pot, not to the emitter of Q1 like the old schem.
Bye
- clintrubber
The one you indicated looks a 25uF, but you might want to know the other one connected to the collector of TR2 ? That one looks a 6.4 uF, looking at the number-spacing & the point-style they use at other components.
- Aharon
Some links expired /are missing so I thought I'd refresh the thread with this schem,you probably know this one.
http://www.schematicheaven.com/effects/ ... driver.pdf
Aharon
Aharon
- Electric Warrior
I just fought myself through dozens of Power Boost and Overdriver gut shots. Here's some variations of the circuit:
any mistakes?
any mistakes?
- analogguru
Yes... after a quick view at least the 22µF (4µ7) from the collector of the third transistor shouldn´t connect to the base instead it should be connected to the junction 4k7/0,01µF (one row to the left).Electric Warrior wrote: any mistakes?
- Electric Warrior
uh
That one used to be right, but I had mistakenly used the symbol for a regular capacitor. must have happend when I "fixed" it.
thanks a lot for spotting it right away, AG!
- Electric Warrior
no idea, I didn't build one yet. I just had a close look at the circuit to get an overview. I think I'll go for the second version of the power boost..
- Electric Warrior
another update. the smaller electrolytics in the later versions are 10µF, not 4,7µF
- Dr Tony Balls
I built one of these for a friend using BC109s. Came out sounding pretty damn good, and before sending it to him I added a master volume out the side upon request.
he quoted "it's the best distortion I've ever had". I dont know if i'd go THAT far...but its a still a rad pedal.
I hope you'll find those pics useful as wellElectric Warrior wrote:I just fought myself through dozens of Power Boost and Overdriver gut shots. Here's some variations of the circuit:
http://www.megaupload.com/?d=S3OUCL39
- Aharon
Dr Tony Balls wrote:I built one of these for a friend using BC109s. Came out sounding pretty damn good, and before sending it to him I added a master volume out the side upon request.
Hey Dr Tony ,did you just stripboard it and which schem did you use...?
Aharon
- Dr Tony Balls
yup!, used this vero layout, which checked out against the original schematic that you posted.
http://aronnelson.com/gallery/main.php/ ... d.jpg.html
- .Mike
I plan on building one of these. Out of curiosity, I modeled the three circuits with the gain up all the way to check out the difference in waveforms. In case anyone is interested, here are the results:
I'll probably do the frequency response later, and if anyone is interested, I'll post that if/when I get it done.
Mike
Mike
My website: America's Debate | My effects site: Just one more build...
