Colorsound - Power Boost / Overdriver
Electric Warrior
Has thanked: 23 times
Been thanked: 104 times
Post by Electric Warrior »
pf_fan wrote:
Electric Warrior wrote:I just fought myself through dozens of Power Boost and Overdriver gut shots. Here's some variations of the circuit:
I hope you'll find those pics useful as well :)
http://www.megaupload.com/?d=S3OUCL39
sorry, nothing new that I can make out.
Maybe I should have mentioned in the shematic that the later Overdrivers have a 10µF cap at Q1's emitter..
Rocket Roll
Been thanked: 38 times
Post by Rocket Roll »
I wonder - could anybody provide the original 18V Overdriver schematics and/or layout, so that we could use a 17V charge-pump (http://www.generalguitargadgets.com/ind ... &Itemid=26) to make a clone of it?
Electric Warrior
guess what I did on page 4? :)
here's my layouts, I hope I didn't mess up too bad..
blueduck577
Post by blueduck577 »
i just built one of these off of the hand drawn overdriver schematic dated 6-14-71... and it doesn't sound like an overdrive to me at all. it does the clean boost but when it distorts it sounds more like a fuzz face to me. like others said it's sounds sort of splatty and misbiased. is this what it's supposed to sound like? i used 2N5088s for the transistors... I have some BC108s and some 2N2222s on hand also, though others have said the transistors don't make much of a difference.
it's late, so I haven't had the chance to crank the amp.
Rocket Roll
Electric Warrior wrote:guess what I did on page 4? :)
Great, thanks a million! Could you maybe make a PCB layout, if that's not too much to ask?
Electric Warrior
blueduck577 wrote:i just built one of these off of the hand drawn overdriver schematic dated 6-14-71... and it doesn't sound like an overdrive to me at all. it does the clean boost but when it distorts it sounds more like a fuzz face to me. like others said it's sounds sort of splatty and misbiased. is this what it's supposed to sound like? i used 2N5088s for the transistors... I have some BC108s and some 2N2222s on hand also, though others have said the transistors don't make much of a difference.
right, it's a boost. does yours sound anything like this?
no, why don't you make one yourself?
Brink
Been thanked: 18 times
Post by Brink »
Rocket Roll wrote:Great, thanks a million! Could you maybe make a PCB layout, if that's not too much to ask?
One already exists: http://www.aronnelson.com/gallery/main. ... alNumber=3
jrod
Has thanked: 413 times
Been thanked: 46 times
Post by jrod »
Electric Warrior
these are all for the Overdriver. Rocket Roll was looking for Power Boost layout, which is not 100% compatible with the Overdriver PCB layouts posted. The 12k resistor at Q1's emitter connects with Q2's collector in the power boost.
For some reason the .1µF capacitor across the bass pot is missing in those layouts.. :hmmm:
blueduck577
this thing doesn't like buffers. running direct guitar -> overdriver -> amp sounds fantastic. but when I inserted it in my signal chain after a boss SD-1, it became splatty and had treble emphasis. maybe thats why I felt it sounded misbiased earlier.
oh well, looks like it's going to replace the SD-1 anyway, and all of my other pedals are true bypass. maybe I'll just put it first in the chain. either way this thing sounds great with the amp going full tilt.
.Mike
Been thanked: 31 times
Post by .Mike »
Hey guys,
I put together an original layout for this using the "Overdriver" schematic, and thought I would share. It's kind of niche layout, so it won't be suitable for everyone. This is the second layout I have ever done.
This is for a long-term multi-effects unit I'm building for myself. I will do at least 10 different original layouts when all is said and done. I'll be posting the project files for each as I compete them. All of my layouts will have: Board-mounted pots (meant to mount vertically); Volume pot on top; 4" x ~2" max dimensions; and Molex jacks for in/out/power/ground connections. I've already released my PIC tremolo, but it disappeared a while back and I haven't had a chance to repost it yet.
Anyway, here are all the files for anyone who is interested:
CSOD.zip
(389.15 KiB) Downloaded 621 times
I've included: ExpressPCB files (.pcb, .sch); PDFs of the PCB, SCH, toner transfer, layout, and pseudo-silkscreen; images of etched board; images of completed build.
For the pseudo-silkscreen (fakescreen?), I toner transfer it onto the component side using photo paper, soak, and rub off all the paper except a thin layer to make it legible on the component side. If you do this, make sure you flip the image to reverse it.
Finally, here are some photos in case you just want to look: link.
Enjoy! :)
Mike
My website: America's Debate | My effects site: Just one more build...
yeeshkul
Post by yeeshkul »
Guys is there any chance to find out whether Gilmour's Power Boost (1972 - 1977) was 9V or 18V version?
TheLemon
Been thanked: 23 times
Post by TheLemon »
yeeshkul wrote:Guys is there any chance to find out whether Gilmour's Power Boost (1972 - 1977) was 9V or 18V version?
It was probably 18v, the version i cloned mine after
jzilla
Post by jzilla »
Dr Tony Balls wrote:yup!, used this vero layout, which checked out against the original schematic that you posted.
http://aronnelson.com/gallery/main.php/ ... d.jpg.html
i'm thinking of trying this for my first stripboard build. can someone tell me what the red squares on the stripboard represent? eg one is above the left transitor. another to the right of R3.
many thanks!
-j
SPeter
Been thanked: 80 times
Post by SPeter »
many thanks!
-j
The red squares show where to cut the strips!
:D
jzilla
Post by jzilla »
many thanks!
-j
:D
thanks!
GeekMacDaddy
my favorite amplifier: Gabriel Sound Garage Voxer 33
Post by GeekMacDaddy »
The layout calls for a 200pf cap. I replace that with (or you could put on a switch) a 470pf, and it gives the pedal it's missing bottom. :D
jzilla
Post by jzilla »
GeekMacDaddy wrote:The layout calls for a 200pf cap. I replace that with (or you could put on a switch) a 470pf, and it gives the pedal it's missing bottom. :D
thanks for the tip! what size enclosure would you recommend using btw?
GeekMacDaddy
Should fit into anything.
jzilla
Post by jzilla »
GeekMacDaddy wrote:Should fit into anything.
oh yeah? even a 125B? for some reason i was under the impression it needed a bigger enclosure...
