Dan's Duo
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
A friend complained that his old "plug-in" Orange Squeezer was stolen at a gig. He said he sometimes liked the sound of the Squeezer into the Dan Armstrong Distortion box. As each circuit just needs one op-amp, I thought I'd make best use of a 4558, and build a squeezer on one side and a distorter on the other. I added level pots for both, and bypass switches, so you can bypass everything or use each effect alone or both together.
The attached pictures show the PnP and the layout. You can work out the external connections yourself (or some kind person can draw them up over my diagram).
Enjoy!
Thank you Chris :)
mictester wrote: Enjoy!
I will! Thanks again :)
SPeter
Been thanked: 80 times
Post by SPeter »
:thumbsup
:D
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Mictester, could you explain, why you changed some parts values in the blue clipper part?
Why such high values for the voltage divider resistors? Doesn´t that increase hiss?
The 22nF cap at the output tames the treble a lot, I guess?
Has thanked: 218 times
Been thanked: 857 times
Some suggestions to ensure succesfull etching as wel as layout hygene:
Then.
I consider this resolution way too crude for etching. Better post it at a far larger (say 3000 px wide) size with the suggested real life size. and let the printer do the resizing. Iview is excellent for that. Other than that, the component pads are rather small.
coldcraft
Has thanked: 38 times
Been thanked: 84 times
Post by coldcraft »
I'd like to reiterate what was just suggested.
I won't make any comments about the layout provided here, but I etch for people all the time and its very frustrating to receive layouts that have tons of empty space and small traces and/or pads with very little space between them. It is MUCH easier to transfer/etch/drill layouts with ground plans and and larger isolation between traces. I'm not saying its easier to achieve a workable product, but its more easily reproducible. I find myself having to make fewer extras in case one doesn't quite transfer correctly or over-etches.
The results are much better if the effort goes to transferring more mask/pnp than it is to etch more copper. YMMV, these are just my opinions from experience.
mictester
Post by mictester »
roseblood11 wrote:Mictester, could you explain, why you changed some parts values in the blue clipper part?
The increased resistors were to reduce the input loading (part of the original sound was the treble loss introduced by the original lower values), and the 22n tames the resultant top end. It sounds pretty good for such a simple circuit!
mictester
Post by mictester »
Dirk_Hendrik wrote:Some suggestions to ensure succesfull etching as wel as layout hygene:
Then.
It was a rushed job, and probably not up to my usual standard! I etched a batch of ten of these, and they were all fine, however.
I've done a further version which includes CMOS switching which I'll put up here this week as an example of what can be done with CMOS and to show how much simpler the off-board wiring becomes.
roseblood11
Inspired by the Dan´s Duo, I combined mictesters Really Cheap Compressor and the Vox 1901 Distortion:
https://www.freestompboxes.org/viewtopic ... wrapheader
