" The Fiendishly Fun Way to Master Electronic Circuits!
Fully updated throughout, this wickedly inventive guide introduces electronic circuits and circuit design, both analog and digital, through a series of projects you'll complete one simple lesson at a time. The separate lessons build on each other and add up to projects you can put to practical use. You don't need to know anything about electronics to get started. A pre-assembled kit, which includes all the components and PC boards to complete the book projects, is available separately from ABRA electronics on Amazon.
Using easy-to-find components and equipment, Electronic Circuits for the Evil Genius, Second Edition, provides hours of rewarding--and slightly twisted--fun. You'll gain valuable experience in circuit construction and design as you test, modify, and observe your results--skills you can put to work in other exciting circuit-building projects.
Electronic Circuits for the Evil Genius:
Features step-by-step instructions and helpful illustrations
Provides tips for customizing the projects
Covers the underlying electronics principles behind the projects
Removes the frustration factor--all required parts are listed, along with sources
Build these and other devious devices:
Automatic night light
Light-sensitive switch
Along-to-digital converter
Voltage-controlled oscillator
Op amp-controlled power amplifier
Burglar alarm
Logic gate-based toy
Two-way intercom using transistors and op amps "
Enjoy!
http://www.freebookspot.me/Comments.asp ... t_ID=72247
