Mxr - Noise Gate / Line Driver
daniel.madeireira
Post by daniel.madeireira »
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
The scheme has found with some changes of errors in other schematic
someone gives him? is right?
thanks
kdude34567
my favorite amplifier: VHT 2/50/2
ADA MP1
Marshall 1960B cabs
Completed builds: Custom Made Rack Amp & Effects Switcher & Foot Controller
MXR Phase 90: 70s Script mod, '70s Block mod
Restore/Rebuilds: MXR Distortion+, Flanger, Phase 100, Phase 90 MicroChorus, MicroAmp, NoiseGate, Blue EQ10, Mutron Phasor II, ElectroHarmonix PloyFlange, Commande Delay, DOD 250OD, Zeus 8444 Preamp, Thomas Organ CryBaby, Westbury W20 Tube Preamp, Maestro EchoPlex SE1 Sireko
Post by kdude34567 »
I know this post was some time ago, but I have an original 1978-1980 grey MXR NoiseGate that hasnt worked for years. I finally got around to repairing it & had some issues. Then I found this thread.
Long story short, is I got it working & it is gating. But I'm having the exact same problem as you guys had that discussed on pages 3 & 4 of this thread. It's where when the gate is engaged it's filtering down or squishing the incoming guitar signal & it's at 1/2 volume & distorted. When the gate is off, the guitar input signal is full level & proper.
It should be noted that I changed a few components on my stock pedal to those discussed in this thread. It wasn't working right before I changed the components & it started gating after I did. Does that mean the original MXR design has some flaws in it? Because the pedal never did work 100% correctly since the day I bought it back in the late '70s as a teenage rock guitarist. Anyways, here the components I changed:
1M --> 1.8K (between JFet gate & 150K)
22K --> 680 (between 5.1V Zener diode & Vcc)
680 --> 4.7K (between -IN of U1 or U1a going to gnd)
1uf --> 2.2uf (same as the 4.7K)
What did you guys finally come up with that fixed the issue?
Kdude
Lead Guitarist White Lie & Guitar Gods
Musical Instrument/Gear Aficionado, Collector,Trader, Restorer, Repairs
Product Manager/Application Engineer Electronic Security Industry
Techno Geek, Half-Baked Inventor, Wannabe Scientist
ranko0537
Post by ranko0537 »
kdude34567 wrote: 22K --> 680 (between 5.1V Zener diode & Vcc)
I am figthing with this too, but I think that this resistor shouldn't be replaced. Try to leave it at 22k.
rockwell4
Post by rockwell4 »
any idea to add send and return so i can trigger gate from input signal
