A92 Transistor alternative?
jimosity
Post by jimosity »
Does anybody know what kind of alternative transistor I can use in place of an A92.
Looks like the A92 is a PNP in a TO-92 case.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
jimosity wrote:Does anybody know what kind of alternative transistor I can use in place of an A92.
That sounds like it could very well be a 2SA92 Germanium PNP transistor in a TO-92 case,if so,you may be able to use one of the following as an alternative replacement:
AF124 to AF126
AF200
2SA218 to 2SA227
Could you post a pic of the original transistor?.... :)
Has thanked: 568 times
MPSA92 perhaps :wink:
PokeyPete
Been thanked: 43 times
Post by PokeyPete »
bajaman wrote:MPSA92 perhaps :wink:
On the nose !! :applause:
I found a couple data sheets for the A92 and it is a silicon PNP 300V Vce/Vcb, .5A, 50Mhz, Hfe 80-250 transistor.
As is an MPSA92 which is easy to find.
–Hunter S. Thompson
MPSA42 is the complement - I use these a lot - they are quite common in the higher wattage transistor power amplifiers - Motorola devices :wink:
Post by DrNomis »
Thanks for that Bajaman.... :thumbsup
PokeyPete
Post by PokeyPete »
bajaman wrote:MPSA42 is the complement - I use these a lot - they are quite common in the higher wattage transistor power amplifiers - Motorola devices :wink:
I use them with nixies.
–Hunter S. Thompson
