A92 Transistor alternative?
Posted: 16 Dec 2010, 06:28
by jimosity
Does anybody know what kind of alternative transistor I can use in place of an A92.
Looks like the A92 is a PNP in a TO-92 case.
Re: A92 Transistor alternative?
Posted: 16 Dec 2010, 07:43
by DrNomis
jimosity wrote:Does anybody know what kind of alternative transistor I can use in place of an A92.
That sounds like it could very well be a 2SA92 Germanium PNP transistor in a TO-92 case,if so,you may be able to use one of the following as an alternative replacement:
AF124 to AF126
AF200
2SA218 to 2SA227
Could you post a pic of the original transistor?....
Posted: 16 Dec 2010, 07:45
by bajaman
MPSA92 perhaps
Posted: 16 Dec 2010, 07:57
by PokeyPete
bajaman wrote:MPSA92 perhaps
On the nose !!
I found a couple data sheets for the A92 and it is a silicon PNP 300V Vce/Vcb, .5A, 50Mhz, Hfe 80-250 transistor.
As is an MPSA92 which is easy to find.
Posted: 16 Dec 2010, 09:14
by bajaman
MPSA42 is the complement - I use these a lot - they are quite common in the higher wattage transistor power amplifiers - Motorola devices
Posted: 16 Dec 2010, 09:45
by DrNomis
Thanks for that Bajaman....
Posted: 16 Dec 2010, 10:17
by PokeyPete
bajaman wrote:MPSA42 is the complement - I use these a lot - they are quite common in the higher wattage transistor power amplifiers - Motorola devices
I use them with nixies.
