Proco - Big Box Rat 1978  [schematic]
peps1
Post by peps1 »
Anyone go a Proco Big Box Rat 1978 and fancies helping out with the missing values on this layout?
PokeyPete
Been thanked: 43 times
Post by PokeyPete »
This is according to a schematic I have. It was a very close match to your board.
–Hunter S. Thompson
PokeyPete
Post by PokeyPete »
Ooooops !! :oops:
Looks like an issue with the image link. I'll see if I can figure out the issue.
–Hunter S. Thompson
PokeyPete
Post by PokeyPete »
ALRIGHT!! :D
The main differences I saw were:
Your 560R was 360R on the schematic. And, there was a 2M2 pull-down resistor
on the input side of the 22n capacitor. Other that that, all matched quite well.
(The 1N4002 was a 1N4001 on the schematic). Hope this helps !!
PP
–Hunter S. Thompson
peps1
Post by peps1 »
Hey Pete,
Thanks for that!
I found a 1986 schematic last-night, and used that to get this.
Will do a a bit more research on the values changing over versions.
PokeyPete
Post by PokeyPete »
Looks like you didn't need my help after all. Darn, a day late and a dollar short again. :slap:
–Hunter S. Thompson
peps1
Post by peps1 »
oh believe me, having someone else come up with the same numbers is ridiculously helpful, my schematic reading are notoriously bad!
So sincerely thank you!
batteryacidtea
Has thanked: 57 times
Post by batteryacidtea »
it seems to be the same as the tonepad's rat.
bstokpunxcrew
Post by bstokpunxcrew »
hi everyone! can someone tell me is this verified schematic? what is the pots value?
i made rat clone using this topic and have some problems. effect doesn't work so good beacuse it's getting distorted very fast. i don't have so much ability to change the tone cause you can hear the tone is changing between 2 and 5 o'clock only. volume is ok. the sound at all have so much bass.
someone can help me with this?
