WTT / WTB 1n4005  [found/sold]
Locked
the3secondrule
Completed builds: GGG Phase45
Fuzz Factory Clone
Shin Ei Companion Fuzz
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
Has thanked: 24 times
Been thanked: 13 times
Post by the3secondrule »
hey y'all,
need a single 1n4005 for a fulldrive clone - happy to trade or buy, i have a few opamps/germ transistors. usually get my parts from smallbear, they don't stock them. it's really not worth me placing another order elsewhere from, but I'm happy to pay postage from wherever. I'm in newzealand BTW...
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
Any 1N400x will do I suppose, probably the differences are too small to matter in a stompbox. And even then, I cannot that there are no suppliers for this in New Zealand.
At least order what you can from futurlec, especially potentiometers. Will matter dollars on shipping alone..
http://futurlec.com/DiodesGen.shtml#General
the3secondrule
Fuzz Factory Clone
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
modman wrote:Any 1N400x will do I suppose, probably the differences are too small to matter in a stompbox.
you're right :mrgreen:
Good point.
from looking at the datasheet http://www.fairchildsemi.com/ds/1N%2F1N4001.pdf the only difference is "peak repetitive reverse voltage". I don't know what that means exactly, but I don't expect to encounter 1000v in a stompbox, so any old 1n400* should be fine
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
A 1N4007 Diode should do fine,they're fairly common,I have a whole heap of them on a bandolieer at home..... :)
If the diode is being used as reverse polarity protection,you can use any of the diodes from the 1Nxxxx series..... :)
the3secondrule
Fuzz Factory Clone
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
Actually, I believe it is being used as a clipper. still, after looking at the datasheet, I think any old 1n400* should be fine
PokeyPete
Been thanked: 43 times
Post by PokeyPete »
the3secondrule wrote:from looking at the datasheet http://www.fairchildsemi.com/ds/1N%2F1N4001.pdf the only difference is "peak repetitive reverse voltage". I don't know what that means exactly, but I don't expect to encounter 1000v in a stompbox, so any old 1n400* should be fine
Gosh! I'm old.....this used to be known as PIV...peak inverse voltage. You know a diode only conducts in one direction, normally. However, if you apply enough force (voltage) in its reverse, non conducting, direction it will break down and begin passing current. That point of sustained reverse voltage resulting in reverse current flow is the PRRV.
–Hunter S. Thompson
Locked
