Baja B K Butler Tube Driver  [documentation]
lutor
my favorite amplifier: Mesa
Completed builds: Catalinbread Hyper pak 2 , B K Butler 2, 3Legged dog, Soldano Supercharger GTO Jfet, MXR Phase 90, Zvex Fuzz Factory, Bartolini NTMB3, Fulltone Bassdrive 2, Gruntbox,MM Stingray Bass preamp,Emma ReezaFratZitz, Jumbo Tonebender, Freya Slo 100 Emulator, Dr. Boogie Emulator, Insanity Box, Fulltone OCD, Fuzz Face Germanium, Fuzz Face Silicium,Crunch Burnig DSM, Ross Compressor, Nurse Quaky, Purple plexi 800, EH Pulsar.
Been thanked: 20 times
Post by lutor »
The final result:
my butler.JPG (44.86 KiB) Viewed 2789 times
lutor
Post by lutor »
Another one picture :
my butler_.JPG (54.16 KiB) Viewed 2776 times
lutor
Post by lutor »
Recently I have changed some other value to the resistor and cap obtaining a still better result. Now every valve will find the just one bias set point.
supergigi
Post by supergigi »
lutor wrote:Another one picture :
Hi Lutor,
great work :applause:
Where you bought the box ?
Thank in advance.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Hi Everyone,
I have just finished working on my Tube Driver Pedal,finally fixed the loud buzzing issue(had to completely redesign the stripboard layout),
anyway,with no guitar plugged into the input socket,and with both the Level and Drive controls turned up full,with both eq controls set to 12:00,all
I am getting now is a hissing noise,no mains buzzing,geez this pedal is quiet...
I've uploaded some pics I've taken of my Tube Driver build.
gabs_gem
Post by gabs_gem »
Can anyone post the BK Butler enclosure measures?
aquataur
Been thanked: 27 times
Post by aquataur »
Folks,
you make case designs that makes my jaw drop, thumbs up!
-helmut
ajmc0116
Post by ajmc0116 »
Hi forum! Great job on all the boxes they look awesome! I have just started this project and I am about to etch the pcb myself, was just about to go buy some double sided board when I had an idea, I though about etching two seperate single sided boards, since I have plenty lying about, with the top and bottom circuits and drill each board separately then I would just glue the two together with some epoxy with the pads exactly alligned. Is this a plausable idea? Or should I just go and use the normal double sided pcb "pocket style" etch?
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
ajmc0116 wrote:hen I would just glue the two together with some epoxy with the pads exactly alligned.
Just mind the length of your component's legs? An IC socket won't reach the other side of the PCB as an example.
If it's ok, just drill two same holes on each PCB, align these, glue, and the drill the others. BUT you need to be sure that you're drilling vertically enough to have your holes centered correctly on each side... Don't know if it actually worths the hassle...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lutor
Post by lutor »
I do not understand because every man wants to complicate own life! The same circuit is possible in the single side rather than the double side. :?:
ajmc0116
Post by ajmc0116 »
Okay im interested :D , im am still some what of a newbee at pedal building :? , so i don't really trust myself with designing the etch, if you have a single side etch pattern that you could post on the forum that would be amazing!
lutor
Post by lutor »
This is a version changed of my perfboard for pcb adapted.
Layout_BKTube_.pdf
(183.15 KiB) Downloaded 993 times
ajmc0116
Post by ajmc0116 »
Okay so I just finished my circuit board, now the last hurdle for me is to wire this puppy up, unfortunately I'm a little confused with what wire goes to what. I am using an external wallwart transformer so I have a power jack on my enclosure. Anyway I was wondering if any body has a wiring diagram for this project? Also I am planning on just using a 3dpt switch instead of a dpdt switch because I have one lying around, so a wiring code that corresponds with the circuit board would also be very useful. :D
Thanks in advance!
ajmc0116
Post by ajmc0116 »
You know what, that was a dumb question, I will do some more research and figure it out :thumbsup
Post by DrNomis »
Personally I think that there is no such thing as a "dumb question",all questions are valid,and it is perfectly okay to ask questions,that is how we,as human beings,learn... :)
ajmc0116
Post by ajmc0116 »
Thanks, i understand but all it takes is a little browsing through the interweb :)
ajmc0116
Post by ajmc0116 »
Okay so i did some research and i see that all you have to do is wire the outside posts of the 3DPT switch just like the DPDT switch and just omit the middle posts? Will this work? since the resistors for the LED's and the actual LEDs are in the circiut? so there is no need for middle posts? or am i missing something :?:
Post by DrNomis »
Here's how I wire up a 3PDT footswitch,I use the two outer poles to do the switching in and out,like a standard DPDT footswitch,then I solder a wire to the centre lug of the middle pole,and i solder the other end of the wire to circuit ground,now,I solder a resistor to the "in" lug on the middle pole,and connect that to the cathode of the indicator led,the led's anode goes to +V.
If you decide like me to use a 3mm Blue led,try using a resistor value like 8.2k,3mm blue leds tend to be incredibly bright,so you need a higher than usual resistor value to tame the brightness,10k should work too,but haven't tried it.... :)
Post by DrNomis »
Here's a diagram i just drew up just to clarify things,I've wired all my pedals like this,works great,hope this helps.... :)
ajmc0116
Post by ajmc0116 »
Thanks so much! This helps a lot!
