Baja B K Butler Tube Driver  [documentation]
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
No worries,let me know how your build goes,my build is still going strong and still very quiet,no mans hum.... :)
Post by DrNomis »
I'll try and upload a diagram of my redesigned stripboard layout that I used to fix the mains hum problem....stay tuned....:)
stratogavster
Post by stratogavster »
Can anybody verify the SINGLE LAYER PCB version that lutor posted?
Would appreciate any input!! making these things on double layers in a pain in the ass :(
Hope somebody can help!!
:D
stratogavster
whoops!! add to my post....anybody verify any of the single layer pcbs on here for the BK Butler tube driver?
Thanks all!!
supergigi
Post by supergigi »
Hi at all,
has somebody the Vref on tube pins and IC pins ?
Thanks in adavance.
Post by DrNomis »
For the IC,you should see the following voltages on the pins:
Pin 1: 0V
Pin 2: 0V
Pin 3: 0V
Pin 4: -14V
Pin 5: 0V
Pin 6: 0V
Pin 7: 0V
Pin 8: +14V
Note,I have 68K resistors on the anodes of the valve in my pedal,you might have slightly different voltages,anyway on the valve pins you should see these voltages(as per my tube driver 4 knob build):
Pin 1:6.35V
Pin 2:-12.93V
Pin 3:-13V
Pin 4: 0V
Pin 5: 12.6V AC
Pin 6: 5.96V
Pin 7:-13V
Pin 8:-13V
Note 2:You may have different voltages on pins 4 and 5.
Post by DrNomis »
You might also get different voltages on pins 1 and 6 depending on what valve you're using and whether it is new,or old..... :)
Post by DrNomis »
To all those wanting a good Vero/Stripboard layout for the Baja BK Butler Tube Driver,and Real Tube Driver,please stay tuned,a friend of mine gave me a 3-In-1 Printer/Scanner/Copier,I'll get it up and running with my computer and will draw up the layout and scan it into my computer so I can convert it to a downloadable PDF document,I'll get it all sorted out ASAP.... :)
Cymbal Monkey
Post by Cymbal Monkey »
Yes this is an old thread but THANK YOU BAJA!
Cymbal Monkey
I made a proposed bill of materials, there are some problems like the bias pot, but I think it's okay. Lemmy know if you have suggestions or if you find things that I flat out failed at. Thanks!
snafuX
Post by snafuX »
hey guyz just finished i gotta a question!!
it's possible to power it up with a 500ma transformer or is it too low???
thank a lot
500mA should work okay - give it a try :wink:
snafuX
Post by snafuX »
ok but i got a problem with noise
i think it is ac noise
can you tell me a good way to ground it a simple grounding diagram
thank you very much
Post by DrNomis »
Snafux,
If you wire the heater connections for the 12AX7 valve to pins 4 and 5,it will need 12.6V AC at 150mA,so to find out how much total current needed to supply the pedal with,just add 150mA to whatever the rest of the circuit draws,so with your 12V AC @ 500mA plugpack,150mA of it will be supplying the valve heater,leaving 350mA for the rest of the circuit,which I think should be fine,you may need to use a 10 Ohm/5 Watt resistor in place of the 33 Ohm/5 Watt resistor that's going to the valve heater,changing this resistor from 33 Ohms to 10 Ohms brings the heater voltage up to where it should be.... :)
Post by DrNomis »
Snafux,
Is your noise problem a mains hum noise that gets louder when you turn up the drive control?..... :)
Is it possible to post a pic of your build?.... :)
snafuX
Post by snafuX »
yes i think it is, and it gets louder when you turn up the gain pot
unfortunately i can't take pictures now
i've used the bk butler rev 2 posted by lutor
can you explain me how to wire the ground in the box jacks have to be isolated from the box? eccc....
sorry but it is my first tube project
snafuX
Post by snafuX »
wo wo wo what 5w resistor to what????
didn't notice any 5w resistor iin the layout !!
where have i to place this resistor?
snafuX
Post by snafuX »
....heater?? i'm using a noval ceramic tube socket...
someone is getting confused with the Baja Real Tube Drive project - different project :wink:
snafuX
Post by snafuX »
anyone out there can help me with the grounding problem, i really need this effect, so please.... :)
