Baja B K Butler Tube Driver [documentation]
- bajaman
- Has thanked: 566 times
- Been thanked: 2014 times
sample sounds - Anything by David Gilmour - Pink floyd etc.
- bajaman
FWIW, I borrowed a Butler, and AB'd it against Bajaman's Real Tube Driver. I gave the Butler back.
thanks for AB'ing them minor7th.
I have had some very positive feedback from folks that have bought Baja RTO's from me too.
Remember- my sound might be your torture, so YMMV.bajaman wrote:FWIW, I borrowed a Butler, and AB'd it against Bajaman's Real Tube Driver. I gave the Butler back.I wonder if it is the dual regulators or the simple tone control - I love the simple tone control, because it is very easy to dial in the sweet spot for single coil or humbuckers.
Looking at it as an end user, the RTD didn't need as much tweaking to get into The Zone, and was still flexible enough to cope with the crap I put through it. I had my sound guy there (cos he has to listen to it) and he was happy to leave the RTD in the chain. It reacted well to, and well with, the other effects. My main guitar is a strat with 3 x dual rails that can be split, with 3 x toggles superstrat phase swtiching (suck on that, Brian May...
I built it with a OPA2134 cos I had a few sitting around and TL0x2s are so... Common. I tried a couple of valves in it before I boxed it, and settled on an EH- for now. More to come there.
As far as both of them go I was told I as the day went on I made a subtle change to my settings to use my other fx to enhance the RTD/Butler... Interesting.
We did decide to take a leaf out of the book of the esteemed Mr Gilmour and I will be building another. One to warm the signal over, and another for those high gain moments...
Summary- Basically, I didn't feel like I was missing out on anything handing the Butler back, if you get what I mean. What more can I say, except again, YMMV.
Thank you, Mr Man!
m7 ![vibes [smilie=vibes.gif]](./images/smilies/vibes.gif)
Hi Baja,
Can you please explain more about the transformer of the BK Butller version, I guess it's not a regular 12vAC.
You wrote at the beginning:
Dror
What do you mean by suitable or toroidal transformer?You will need a suitable 12vAC power pack for this pedal - the original has a small toroidal mains transformer fitted internally near the front of the case.
Dror
- bajaman
Hi dror - sorry - that is all I know
- bajaman
They are cheap nowadays and they radiate a very low hum field when compared to a standard E and I lamination transformer - a major advantage when placed near high gain circuitrywhat is the advantage of the toroidal transformer
Yes. There might be slight differences to the sound, but there's one way to find out whether it's a sound you like. Actually, there's a whole heap you could try- 5532, 072, LM833- basically all the usual suspects for dual opamp DIP-8 packages. (Sorry if I've put down the wong chip there- I' not well and the drugs are niiiiiiiice!rantony wrote:Hi Baja,
Are the 4558 and the OPA2134 100% interchangeable without any modification to the circuit ?
Thanks for this greaaaaaaaaaaat project !
Socket it, and if you don't like it- change it!
Is this version any good? http://diy.musikding.de/berichte/eff/ch ... er_mod.gif It seems to be very simmilar to the GGG version which obviously has problems.
How would I build this with out the bias circuit? Pins 3 and 8 to V - - ?
Also what is the current draw for the circuit? I'd like to get an external 12vac power supply. If anyone has suggestions about a good 12vac wallwart for 120vac input please let me know.
I just registered on this forum :
applause: very good job indeed from BAJA
does anybody have the physical details of the "box" to house all this stuff ?
Hello!
I'm new to this forum and excuse my bad english.
I have been looking for a traced butler tube driver for quite some time. When i saw bajaman's first post in this topic i coudn't believe my eyes. I started building it and i'm having problems with the PCB layout. I noticed that the traced top layer and bottom don't go together as shown on the photographs of the actual PCB. I tried flipping them over and under... It just didn't work out as on the pictures. Bajaman: is the photo of the bottom mirrored? If it were, than it would make sense.
Thx
Thx
Hey
I just went with it, assuming that the picture is mirrored.
Now i have a problem: When the effect is off everything is ok, but when i turn it on, it doesn't play how it should. If i play lightly (don't hit the strings too much) there's hardly any signal, but if i hit the string harder the effects produces somekind of a fuzz tone which immediately shuts down. What could be wrong?
- bajaman
https://i197.photobucket.com/albums/aa2 ... ematic.pngDoes someone have a parts list of resources and pictures of the guts to get a visual? Thanks
pictures here:
members/bajaman/BKBUTLERPICS/
Thank you so much....gregbajaman wrote:https://i197.photobucket.com/albums/aa2 ... ematic.pngDoes someone have a parts list of resources and pictures of the guts to get a visual? Thanks
pictures here:
- seniorLoco
Just an update ....Modz a Butler to Baja specs with a 12au7. Reduced the two 47k anode resistors to 22k for best results and the bias became way more useable. Everything else was to Baja.
Bajaman ....Thanks Heaps
