Page 2 of 16
Re: Baja B K Butler Tube Driver
Posted: 01 Jun 2008, 01:33
by bajaman
sample sounds - Anything by David Gilmour - Pink floyd etc. :wink:
Posted: 01 Jun 2008, 03:39
by minor7th
FWIW, I borrowed a Butler, and AB'd it against Bajaman's Real Tube Driver. I gave the Butler back.
Bajaman- you da man!
Posted: 01 Jun 2008, 06:22
by Dror
Posted: 01 Jun 2008, 07:38
by bajaman
:hmmm: I wonder if it is the dual regulators or the simple tone control - I love the simple tone control, because it is very easy to dial in the sweet spot for single coil or humbuckers.
thanks for AB'ing them minor7th.
I have had some very positive feedback from folks that have bought Baja RTO's from me too.
Posted: 01 Jun 2008, 14:56
by minor7th
Remember- my sound might be your torture, so YMMV.
Looking at it as an end user, the RTD didn't need as much tweaking to get into The Zone, and was still flexible enough to cope with the crap I put through it. I had my sound guy there (cos he has to listen to it) and he was happy to leave the RTD in the chain. It reacted well to, and well with, the other effects. My main guitar is a strat with 3 x dual rails that can be split, with 3 x toggles superstrat phase swtiching (suck on that, Brian May... :) ), so I ran the full gammit.
I built it with a OPA2134 cos I had a few sitting around and TL0x2s are so... Common. I tried a couple of valves in it before I boxed it, and settled on an EH- for now. More to come there.
As far as both of them go I was told I as the day went on I made a subtle change to my settings to use my other fx to enhance the RTD/Butler... Interesting.
We did decide to take a leaf out of the book of the esteemed Mr Gilmour and I will be building another. One to warm the signal over, and another for those high gain moments... ;)
Summary- Basically, I didn't feel like I was missing out on anything handing the Butler back, if you get what I mean. What more can I say, except again, YMMV.
Thank you, Mr Man! :applause:
Posted: 12 Jun 2008, 22:47
by Dror
Hi Baja,
Can you please explain more about the transformer of the BK Butller version, I guess it's not a regular 12vAC.
You wrote at the beginning:
You will need a suitable 12vAC power pack for this pedal - the original has a small toroidal mains transformer fitted internally near the front of the case.
What do you mean by suitable or toroidal transformer?
Dror
Posted: 13 Jun 2008, 01:15
by bajaman
Hi dror - sorry - that is all I know :)
Posted: 13 Jun 2008, 05:03
by Dror
bajaman wrote:Hi dror - sorry - that is all I know :)
I'm just trying to understand, what is the advantage of the toroidal transformer.
And if it's effect the sound
Posted: 13 Jun 2008, 06:44
by bajaman
They are cheap nowadays and they radiate a very low hum field when compared to a standard E and I lamination transformer - a major advantage when placed near high gain circuitry :wink:
Cheers
Posted: 16 Jul 2008, 04:15
by rantony
Hi Baja,
Are the 4558 and the OPA2134 100% interchangeable without any modification to the circuit ?
Thanks for this greaaaaaaaaaaat project ! :wink:
Posted: 16 Jul 2008, 04:42
by minor7th
rantony wrote:Hi Baja,
Yes. There might be slight differences to the sound, but there's one way to find out whether it's a sound you like. Actually, there's a whole heap you could try- 5532, 072, LM833- basically all the usual suspects for dual opamp DIP-8 packages. (Sorry if I've put down the wong chip there- I' not well and the drugs are niiiiiiiice! :blackeye )
Socket it, and if you don't like it- change it!
Posted: 20 Sep 2008, 23:41
by Ikatoch
Is this version any good? http://diy.musikding.de/berichte/eff/ch ... er_mod.gif It seems to be very simmilar to the GGG version which obviously has problems.
Posted: 25 Sep 2008, 04:48
by kyle31
How would I build this with out the bias circuit? Pins 3 and 8 to V - - ?
Also what is the current draw for the circuit? I'd like to get an external 12vac power supply. If anyone has suggestions about a good 12vac wallwart for 120vac input please let me know.
Posted: 29 Sep 2008, 11:58
by guigui1950
I just registered on this forum :
applause: very good job indeed from BAJA
does anybody have the physical details of the "box" to house all this stuff ?
Posted: 29 Sep 2008, 16:16
by RiZsho
Hello!
I'm new to this forum and excuse my bad english.
I have been looking for a traced butler tube driver for quite some time. When i saw bajaman's first post in this topic i coudn't believe my eyes. I started building it and i'm having problems with the PCB layout. I noticed that the traced top layer and bottom don't go together as shown on the photographs of the actual PCB. I tried flipping them over and under... It just didn't work out as on the pictures. Bajaman: is the photo of the bottom mirrored? If it were, than it would make sense.
Thx
Posted: 29 Sep 2008, 19:25
by RiZsho
Hey
I just went with it, assuming that the picture is mirrored.
Now i have a problem: When the effect is off everything is ok, but when i turn it on, it doesn't play how it should. If i play lightly (don't hit the strings too much) there's hardly any signal, but if i hit the string harder the effects produces somekind of a fuzz tone which immediately shuts down. What could be wrong?
Posted: 03 Oct 2008, 20:49
by golson
Does someone have a parts list of resources and pictures of the guts to get a visual? Thanks
Posted: 04 Oct 2008, 00:19
by bajaman
https://i197.photobucket.com/albums/aa2 ... ematic.png
pictures here:
members/bajaman/BKBUTLERPICS/
Posted: 04 Oct 2008, 01:43
by golson
pictures here:
Thank you so much....greg
Posted: 06 Oct 2008, 01:20
by seniorLoco
Just an update ....Modz a Butler to Baja specs with a 12au7. Reduced the two 47k anode resistors to 22k for best results and the bias became way more useable. Everything else was to Baja. :thumbsup :thumbsup :thumbsup
Bajaman ....Thanks Heaps :mrgreen:
