Höfner - Wah Wah [schematic]
- Manfred
- Has thanked: 1597 times
- Been thanked: 1300 times
Is this PCB layout suitable for your pedal enclosure.
I still need to finish it in accordance with the schematic.
You can print the layout, cut it out and see if it fits in your enclosure.
Amazing Help!!
Do you have the gerber files (Projecti files) of this, so i can print a Legit PCB ?
Thank you so much
- Manfred
Here the PDF again, a conductor was missing.
The copper side and drilling data:Do you have the gerber files (Projecti files) of this, so i can print a Legit PCB ?
- Manfred
I finished the layout and created a modified one that did not require the two wire connections on the copper side. I found the schematic by tracing the board.
For the capacitors I took the values from the schematic in the post above, whether these values are correct I don't know.
The transistors on the picture of the layout are not BC109B according to the package shape, BC549 should work though.
The coil in the layout I chose the pin spacing that fits a FASEL type. Ready to print files: Gerber files: SprintLayout6.0 file: Ready to print files: Gerber files: SprintLayout6.0 file:
@Manfred thats amazing....
I'm really impressed with your help, and you remind me the old comunity in the beggining of online foruns... all the sharing and help that happened in that times... <3
I will print the final circuit without the wire connections, and as soon as i tested i will keep you update here...
many thanks for this help! seriously!!!
- Manfred
@Rebuilder
Can you read or measure the potentiometer value in your pedal?
