Maxx1044 in the UK [found/sold]
- my favorite amplifier: Fender Super 60 or Teisco Checkmate
- Completed builds: Lots and Lots and Lots
Hello all,
Merry Xmas
Does anybody over this side of the pond know where a UK source of these chips can be found? One of the big suppliers (i forget which...) sells the SMD version, but alas i am not a robot and need something more manageable.
Thanks for all the help
Regards
Merry Xmas
Regards
Oooh!
Thanks for link, i shall be using that very soon.
Is the icl7600 pin compatible with the maxx1044? I need to replace them in an existing circuit.
- CRBMoA
AFAIK, yes. But this place is your friend!dperry wrote:Oooh!
Compare the datasheets, and you'll know for sure.
atreidesheir wrote: Let's build some damned pedals!
- frequencycentral
The ICL7660S (note the S suffix) is functionally identical to the MAX1044, with the benefit that it will run off a slightly higher voltage. And cheaper. They go pretty cheap at Rapid Electronics in the UK.
Cool, thanks for all your help guys. I have gone with the chips from doctortweaks. I hope these mold spores will appreciate it!
