Tycobrahe - Pedalflanger  [schematic]
Dirk Hendrik traced the schematic of the Tycobrahe Pedalflanger:
http://www.dirk-hendrik.com/tycobrahe_pedalflanger.pdf
Here is another one with guts:
wc6w.50webs.com/wc6wvint/index.html?fr413.html
merging from a separate thread :)
Professor SourTone wrote:Check out ultra detailed tycho pedalflanger pics in this auction. He has other cool stuff too.
tycho pedalflanger pics on ebay
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
this is nice gut shoot.......
I like their box design..........does somebody have PCB designed for this nice pedal?
thanks Dirk for schematic :thumbsup
boris
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Anybody got any of the gut shots saved from the two dead links? I'd take a shot at drawing a board up.
Image Ken
azrael
Has thanked: 35 times
Been thanked: 87 times
Post by azrael »
This thing looks quite cool. I wonder how accurate the Chicago Iron clone of it is.
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
Supposedly the Chicago Iron is dead on... I need to meet with these guys just to find out. 8)
+1 to anybody having the underside of the pcb.
Skyline FX 2013
chicago_mike
The MN3001 being a dual stage 512 and the slightly easier to get mn3007 being a single stage 1024...
Do I need 2 3007's? not for the delay time but because how the circuit is done? If I were to diy one of these?
Skyline FX 2013
spookybonus
Post by spookybonus »
i have one, are you still looking for the underside of the board pic? i could take one if you need it
borislavgajic
spookybonus wrote:i have one, are you still looking for the underside of the board pic? i could take one if you need it
thanks for this offer!!!
:hug:
do not ask....take camera and do some MACRO mode photos...... :thumbsup
and try to make 90 degree angle shoot of PCB......
thanks
Boris
MarcoMike
Post by MarcoMike »
I bet there's nothing at all on the other side of that pcb...
EDIT: i was referring to the old one, that pcb seems, as old morley's, a single sided pcb with "surface mounted" components...
spookybonus
here ya go...good luck!
*right click on them and choose "view image" to see the whole thing if the image is cut off in here.
borislavgajic
:applause: great photos...!
thanks a lot!!!!
can you please take some more shots of wiring,jacks and whole pedall inside...looks like newer model??
Boris
spookybonus
yeah its one of the newer limited edition purple ones, sounds killer.
here are some pics of the whole inside.
royceprinting.com/2006files/john/PF_1.jpg
royceprinting.com/2006files/john/PF_2.jpg
royceprinting.com/2006files/john/PF_3.jpg[
borislavgajic
Great ....thank you very much........... :block:
spookybonus
no problem!
borislavgajic
borislavgajic
So far I have done this......please add as much component values, and check track side if it is correct..........next is top copper layer..... :thumbsup
Boris
borislavgajic
would be great to see some more photos from different angles.....so I could take a peek at traces under IC-s and other components...... :thumbsup
what BBD is used here? ...MN3207 or MN3007
Boris
Whoismarykelly
Post by Whoismarykelly »
This is sort of curious. I have one but the entire PCB has been coated in a paint-like red substance. Maybe dipped in paint after it was wired with leads? Its weird that the one in this thread is not gooped like mine is.
borislavgajic
Whoismarykelly wrote:This is sort of curious. I have one but the entire PCB has been coated in a paint-like red substance. Maybe dipped in paint after it was wired with leads? Its weird that the one in this thread is not gooped like mine is.
we can goop this one after reverseengeneering iT :mrgreen:
If you can post picture of your pedall,,,?
Boris
