JMP-1 preamp mod for a rear input
mich
Been thanked: 25 times
Post by mich »
I don't know if this is of interest to anyone but I run two rigs, an all tube (Vox AC30 and ac50 A/B'd) with analog stompboxes (sans a gigadelay in the effects loop) based rig and an all solid-state rack based rig with a JMP-1, line6 pod pro and an ada mp-1 (switchable) with bbe sonic maximizer and mostube power amp. Anyways, the JMP-1 is notorious for a front input jack that goes south after a while. Additionally, it does not have a rear input jack like the other preamps i mentioned which is a little annoying when setting up the cabling. So my front input jack went south and I when I opened it up, it just looked like a major PITA to pop out the board and replace the jack. So I drilled a hole about 2 - 2.5 inches right of the power jack on the rear of the unit, installed a mono-jack and ran wires the the input jack and soldered wires to the signal and ground pins on the jack housing. I figured this would only work if the jack was electronically sound but the physical connection of the instrument cable to the jack was what was causing the intermittent connection. Well this seemed to be the case b/c the mod worked. I thought the proximity to the power line may introduce some noise but I don't really think its the case ... I haven't noticed that much additional noise in the line .... may redo with some shielded wire to see if that helps at all. Anyways ....
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
If you replace the wiring with shielded cable can you take a photo of the mod and post it.
I recently had a broken jack on my JMP1 as well, I have had it for 20 years from new, I contacked Marshall and they sent me both front jacks FREE of charge, it wasn't such a big job to pop the PCB out as its only held in place by the rear jack nuts.
So now i have a new lloking repaired JMP1 :)
BTW There used to be a forum about that had some circuit mods for the jmp1 I cant remember what it was called but a google search should find it pretty easy.
mich
Post by mich »
I will. I just got some shielded wire from small bear. Probably do the job this or next week
mich
Post by mich »
I redid the wiring last night. I actually used a simple coaxial cable from an old TV cable hookup. Happy to say that for high gain settings the noise has dropped to pre mod levels
OLd (unshielded wiring) mod:
Jack, old wiring
Jack, old wiring
Input jack relocated
Old wiring, run
Old wiring, run
New, shielded:
Shielded wired jack
Shielded wired jack
Shielded wire soldered to old input jack
New wire run
New wire run
Sorry, crappy iPhone pics
brain_lp
Post by brain_lp »
the thing sounds crazy.... :horsey: :D
awesome!!! :applause:
peoplesguitar
Post by peoplesguitar »
New to the forum. Have been using the JMP for 10 years...best way for me to achieve cranked old Marshall tone without having the soundman after me the whole evening. I use only the plexi 50 patch. A guest sax player stepped on my cord, breaking the input. Got replacement. Four hours later, (the PC standoffs!!!!), got it installed and find the noise level, hiss to be increased.
Like to try your mod, but do not have permission to see the photos that you've posted. Any folks out there know what I have to activate to see the photos? Thanks
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
peoplesguitar wrote:Like to try your mod, but do not have permission to see the photos that you've posted. Any folks out there know what I have to activate to see the photos? Thanks
Usually, becoming a member is enough to see any material posted on the forum. if you still can't see the images after being able to post a message, you should report the problem in PM to a moderator. Did you refresh the page, clear your browser cache, etc. ?
By the way, welcome on board !
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Or reach a post count of 5 by posting in a thread in the Testing section...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
DeanM
my favorite amplifier: Marshall VM 2466
Has thanked: 21 times
Been thanked: 5 times
Post by DeanM »
lolbou wrote:Or reach a post count of 5 by posting in a thread in the Testing section...
Is that what thats for? :slap: wondered about that! lol
lolbou
Post by lolbou »
It's basically for testing. :wink:
