MXR - Smart Gate
Ok here is the reason why I don´t like bootweak pedals... because most of the time there are only a few components inside. This can´t be said about the MXR Smart-Gate:
img126.imageshack.us/my.php?image=cimg0675my1.jpg
img127.imageshack.us/my.php?image=cimg0676dg1.jpg
img507.imageshack.us/my.php?image=cimg0677zu8.jpg
oscarv77
Been thanked: 11 times
Post by oscarv77 »
I have the same pedal with the same blown resistor (100 ohm). Are these your pics?
I already replaced the electrolytic and the diode and the 100 ohm resistor and every time I plug in the input cable, the resistor blows up :(
oscarv77 wrote:I have the same pedal with the same blown resistor (100 ohm). Are these your pics?
No I found them by chance while searching for something different...
I will have a look at the stuff what can be the reason....
Maybe I need some additional infos... let´s see.
Stephengiles
Post by Stephengiles »
Is there a schematic for this? Is there, is there? :roll:
oscarv77
Post by oscarv77 »
Stephengiles wrote:Is there a schematic for this? Is there, is there? :roll:
Nope, not as far as I know... I searched and searched and even contacted MXR, but all I got was the resistor value (since mine was a lump of carbon)
It uses readily available part values, but if there was a full-size component layout, it would have to fit in a rack or a huge box.
oscarv77
Post by oscarv77 »
In cleaning the bench today, I ran across the pedal again, so I did what everyone would do; I took it home and took some pics. I've zipped them up and they are available here: http://val-tone.com/MXR_Smart_Gate.zip
It will be virtually impossible to trace since it's all surface mount components, but if anyone is up to it, I would be more than willing to provide more shots, part values, etc.
So? anyone up for a challenge?
Supafuzz
Post by Supafuzz »
analogguru wrote:Ok here is the reason why I don´t like bootweak pedals... because most of the time there are only a few components inside.
Ingenuity is in simplicity, don't you think?
No, not if it is getting to simple..... finally the car you like to drive also has a motor and a brake-system ?
Supafuzz
Post by Supafuzz »
Brakes are unnecessary. I replaced accelerator pedal with a 2 position switch: pedal to the metal or idle. Simple and works like a charm. Gooped it too.
Perhaps this gate schematic will meet your expectations for adequate number of components. Patents have expired, it's public domain now. Do it in SMT and it should fit in a standard stomp box.
Brian M
my favorite amplifier: Vintage Twins
Been thanked: 54 times
Post by Brian M »
considering half that circuit is for driving a meter, i think you could safely omit that in pedal form.
Supafuzz
Post by Supafuzz »
Why lose the meter? I thought it was established long ago that without visual indicators a majority of guitarists can't hear whether a device is activated or not. :twisted: This one uses gas discharge lamps instead of LEDs, looks very cool :mrgreen:
Brian M
Post by Brian M »
does that add better tone that blue LED's :hmmm:
Has thanked: 218 times
Been thanked: 857 times
Not always. The swamp thang of which I posted the schamatic a week ago has it's weakness in it's simplicity. It pops, is not suted for a reliable pedal form etc etc.
oscarv77
Post by oscarv77 »
kugua wrote:http://val-tone.com/MXR_Smart_Gate.zip,I CANnot download it.do you have BOSS ns2 or other noise gate?take some pics ?
New link: http://rapidshare.com/files/98814904/MX ... e.zip.html
Brian M
Post by Brian M »
I've owned plenty of gear that wasn't simple, that sounded pretty horrid... ADA MP-1 anybody?
I've never used the smart gate, but the PCB layout, and basic lay out of the pedal is beautiful. Still not a big fan of the way they mouth (or not mount) their power jacks... Unfortunately, a lot of the new MXR pedals are good ideas, but executed poorly. the blue box being a good example. is unity volume too much to ask when the volume is all the way up? The new phase 90's distort with way lower input levels than the older ones. Neat and tidy layouts are great, but ultimately mean little when it comes to a product being useful.
