AVX box caps discontinued
Posted: 18 May 2009, 03:40
by MoonWatcher
The truth be told, most of the AVX metal films are the same price or cheaper than the Xicons from Mouser, unless you're ordering in quantities of 500 units or more.
And for a lot of R/C networks where it would take an odd resistor to get the shelf or curve right, the goofy in between cap values can simplify things a bunch.
But my fave thing about the box caps is that I can populate a board in a fraction of the time that those long lead greenies take, and the leads rarely need trimming. It's also easier and faster to solder a slew of caps that don't have leads sticking up all over the place.
Many advantages to the box caps. Just some things to consider (not that you haven't).
Re: Catalinbread - Dirty Little Secret
Posted: 18 May 2009, 08:39
by Seishin
Good point about efficiency! I may have to do a test. We do order caps by the metric boatload though.
[/quote]
Posted: 18 May 2009, 13:52
by paulc
Problem with the AVX caps is they've been discontinued. It's a real drag because I loved those things...
PaulC
Posted: 18 May 2009, 14:16
by Greg
PaulC
There's a company in Australia called Altronics that sell cream coloured boxed metal films that they claim in their catalogue are manufactured by AVX.
Posted: 18 May 2009, 18:01
by MoonWatcher
PaulC
Aw man... That is the letdown of the day! I loved them as well - I've been using them so much that it's become as automatic as tying my shoes.
I guess it's back to the Wimas.
Posted: 18 May 2009, 18:36
by Brian M
PaulC
We had been using AVX box caps for about two years. It was really disappointing when i found out they were going to be gone. I thought they sounded moderately better than wimas, and their construction was more uniform. More than anything else, I liked that Mouser stocked a lot of different values of the AVX caps. .0082, .033 etc. Not so with a lot of other box caps that they keep around
Posted: 18 May 2009, 18:51
by dap9
So then what are you guys using instead of the AVX? Does this mean they'll reach Tropical Fish status in a few years? If so, I'll save the few that I have left
Posted: 18 May 2009, 20:47
by MoonWatcher
dap9 wrote:So then what are you guys using instead of the AVX?
It's back to the Wimas until I find something comparable to the AVX line. And has been already noted, the AVX's seem to have been an improvement over the Wima stuff.
I really liked the AVX plastic casing - softer than the Wimas. I could populate a board with dental surgeon's precision, since the needle nose would hold fast to the AVX casing. Meanwhile, the Wimas would spin around or "launch" from the needle nose on occasion, because of the harder plastic casing.
Posted: 19 May 2009, 00:04
by Greg
PaulC
When did AVX stop making these ?
I guess we're benefitting from old stock in Australia, but we can still get these fairly readily.
These are the AVX we all know:
http://australia.rs-online.com/web/sear ... &R=5373274
These are also claimed to be AVX Brand:
http://www.altronics.com.au/index.asp?a ... &id=R3001A
Posted: 19 May 2009, 02:30
by dap9
MoonWatcher wrote:dap9 wrote:So then what are you guys using instead of the AVX?
If you don't mind, which Wimas do you prefer? I just ordered a bunch of the greenies, and still have a bunch of the AVX, but I'll try the Wimas for my next order. Thanks.
Posted: 19 May 2009, 12:05
by MoonWatcher
dap9 wrote:If you don't mind, which Wimas do you prefer?
I was using the MKS2 series with a 5% tolerance.
http://www.mouser.com/Search/ProductDet ... b6HPI1E%3d
The MKP2 series will also work, but they are more expensive, and there are less values to choose from.
Posted: 19 May 2009, 12:06
by paulc
They killed the line back in Feb. You'll still be able to find them for a bit - they made a ton, but they're going fast.
Posted: 19 May 2009, 13:05
by Greg
Is there anyone else making a boxed metallised poly cap like this ?
Posted: 19 May 2009, 15:28
by RnFR
i was just talking to solidhex about these vishay boxes-
http://www.mouser.com/Search/ProductDet ... oGFJJzQ%3d
supposed to be very nice.
Posted: 19 May 2009, 23:56
by Greg
Thanks RnFR.
At least there's still something similar available.. a bit pricey though for a 10% cap..
Posted: 20 May 2009, 00:20
by soulsonic
Greg_G wrote:
Thanks RnFR.
I just got some of those recently in 220nF value because the AVX ones were sold out (forever, now?). They are nice - good quality. Too bad about the AVX stuff - they are like the early 21st century's Greenies; everyone uses them!
Re: AVX box caps discontinued
Posted: 08 Jan 2011, 14:14
by modman
this thread is a split-off from the
Catalin Dirty Little Secret thread in Boutique Dissected...Makes more sense (a lot) to move it here.
I'm working on cleaning out that thread by way of test in order to keep the bare circuit analysis discussion in that folder.
Posted: 08 Jan 2011, 21:28
by Dan N
Mouser has a few values of the 100 volt XICON 1430 series of box caps. They're not nearly as sexy as the AVX or wimas. They are relatively cheap, and that works for me.
http://www.mouser.com/catalog/specsheets/meb.pdf
