Remote switching for racked effects.
Cymbal Monkey
Post by Cymbal Monkey »
I want to rack mount my effects and have a switch bank on the floor. From what I've been reading, relays seem to be the way to go. Problem is, I don't know what kind or how to do it. So if anyone knows how... that'd help... Musique has a board for true bypass switching with a relay, but some of my pedals (Darkside) are not true bypass. So can anyone give me some help here?
OC26
Has thanked: 301 times
Post by OC26 »
I designed this some years ago. It works fine for a 4 fx rack.
Cymbal Monkey
Can you give me some more info on how to rig this up? (Noobie here)
OC26
Post by OC26 »
Sorry Cymbal Monkey. I'd been busy...
Just put all the circuit above inside a box in your rack. Connect each of the 4 send jacks to your 4 stompbox inputs. Connect each of your outputs to the return jacks. Plug your guitar to the input in the A section. Connect the A section output jack to the B section input jack, and so on. Connect the D section output to your amp.
All switches are momentary SPST. Hook up a 5 pin DIN cable (4 pins for REMOTE A, B, C & D; 1 pin for ground. Connect the other end of the DIN cable to a remote four momentary stomp footswitch.
When powered, a positive going pulse is generated at Ra/Ce, wich resets the unit to full bypass. You can bypass the unit anytime by pressing the Reset momentary switch.
the_ungod
Been thanked: 7 times
Post by the_ungod »
I've once build a midi switch that can control 12 relays for stompboxes... if you need help...
OC26
Post by OC26 »
the_ungod wrote:Hi,
Sure! Much better.
Cymbal Monkey
the_ungod wrote:Hi,
I do need help! This sounds brilliant!
Cymbal Monkey
Could I use an XLR7, ground the housing, and switch 7 effects that way?
OC26
Post by OC26 »
Cymbal Monkey wrote:ground the housing?
I am not sure that's a good idea... An 8 pin DIN system would be better.
The_ungod idea is most effective anyway for a large system
the_ungod
Post by the_ungod »
My system was based on this one...
http://www.jimkim.de/html/guitar01_01.htm
I made a pcb with one midi in, and 4 outputs for relay control. Then i made 4 of these to get 16 out's....
With this 16 outputs i made these options:
1 - Guitar AB
2 - Tuner Out
3 - 15 - FX Pedals
16 - Amp Channel Switch
Of course you can make your own connections.
Here are the files (schematics and pcb)
http://hotfile.com/dl/100803478/876cf39 ... t.zip.html
I've built it in a 2u rack and i control it with an fcb1010...
Some pics
Complete build
Inside View
Chassis
Mounting first relay boards
Power Supply
Assembly
My partner inspecting the job...
More chassis...
The module boards
