Germanium diodes prone to heat damage?
Frequent question abouts LED and other types of diodes.
sch929
Been thanked: 5 times
Post by sch929 »
Are Ge diodes, like the 1N34A Ge, prone to heat damage from soldering?
The measured resistance of a few Ge 1N34A that I have has are ~2ohm which seems silly for a diode?
The diode was not biased, that was just a DMM measurement.
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
sch929 wrote:Are Ge diodes, like the 1N34A Ge, prone to heat damage from soldering?
As any semi-conductor device, I would say yes. Use a pair of pliers as a heatsink whenever you can...
sch929 wrote:The measured resistance of a few Ge 1N34A that I have has are ~2ohm which seems silly for a diode?
A DMM ohmmeter acts as a constant current source (some µA or so). Then it measures the voltage drop accross the probes, and compute resistance according to Ohm's law. I don't know what to expect from a single diode, but if you have a DMM, check it with the diode function?
Now, was the diode actually soldered on the PCB? Measuring DC resistance in circuit can give weird results: there are sometimes other paths to link your two probes.
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
The funny thing is,even though Germanium is heat sensitive,I have never in my whole life ever damaged a Germanium diode by overheating through soldering,I have my soldering station set to 350 degrees C,and have never damaged any semiconductors at all..... :)
I think as long as you are careful,you shouldn't damage any semiconductor devices..... :)
sch929
Post by sch929 »
Thanks guys. I'll try to scrounge up a better multimeter with a diode function.
I had heard about Ge diodes being fragile for a long time, so when sorting old parts I became suspicious of the ones on hand.
Post by DrNomis »
sch929 wrote:Thanks guys. I'll try to scrounge up a better multimeter with a diode function.
Germanium is a funny semiconductor material,I've read somewhere that it can be disolved in water,it is temperature sensitive,more so than Silicon..... :)
