It was meant to say remove the resistor R18 circled in RED
After the resistor follow the trace down under the FV-1 chip to the two pins on the chip that are connected together, the bit circled in GREEN now this track needs to be cut seperating the two pin of the chip (20 and 21). Even after cutting the track between the two pins we can still reverse the mo if needed by placing a blob of solder between the two pins on the chip . (nothing in these mods can't be put back to standard)
Next a wire from the top pad of the removed resistor need to soldered from there to pin 20 ( the lower pin in the white trace) This just reconects the pot to its original control pin.
Adding the second pot now is just as easy. Using 100k linear pot solder one end to the 3.3v and the other end to gnd or just conect each end to the ends of the pot that I have put the white trace on. The centre pin on the pot then goes to the other end of the R18 pad ( bottom pad R18)
If any of this is confusing just ask and i can answer every question, this second picture with the mod done should make it clear.
