As you may or may not know, I've been working on the brand new DIYLC for quite a while. Other projects didn't leave enough free time, so it went slowly.
Anyways, I think it's ready to be shown to the world to get some feedback from you guys. The archive can be downloaded from this address http://diy-layout-creator.googlecode.co ... -0.0.0.zip
The main site is http://www.diylc.org and there is a semi-finished documentation that may be helpful. If you think that something should be added to explain some features better, please let me know. I made it, so everything seems easy to me, which may not be the case for the rest of the world
To run it, both windows and linux users should execute run.bat (the current dir must be set to the same location where that file is).
Have in mind that it's just an alpha version and most of the components aren't there yet. I want to build components that are different and use different bits of the API to make sure that everything works properly. When I'm done with that I'll add more components to fill the gap.
Let me know what you think.
Best regards,
Bane
