Do-It-Yourself Layout Creator [open-source]  [link]
bancika
Has thanked: 16 times
Been thanked: 88 times
Post by bancika »
(relatively) good to hear that. I'll let you know if I find the cause.
It could help clicking on that memory bar once in a while because it will run a garbage collector and free up some memory.
bancika
Post by bancika »
the new version is released yesterday, as always you can find it here http://code.google.com/p/diy-layout-cre ... loads/list
:thumbsup
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Cheers Bancika, I just downloaded the multi-platform beta zip file, going to take it for a spin and will give you some feedback afterwards mate.... :thumbsup
auden100
Post by auden100 »
woohoo! Thank you for your work, Bancika. :block:
Post by DrNomis »
Just gave the Beta version a test-run, no issues so far, all I had to do was download the latest Java Runtime Environment files, install them, and that was it, DIYLC launched straight away.... :thumbsup
PerS
my favorite amplifier: Fender Bassman
Fender Blues Jr
Completed builds: Boss BD2 mod
Folk Drive (small mod's)
Hony Bee clone
BYOC Mighty Mouse
Post by PerS »
Hi Bancika
Looks great and works great on first try. I have run your previus with success. Will test it a bit moore later. Good jobb.
One question - Is it possible to import drawings from previus versions? I got a blank workspace when loading a drawing I made in previus version. It reads the file and I see the file name on top but no wisual drawing/components/lines.
Just so I know if I over looked something...
//Per
Post by DrNomis »
Hi Bancika, here's a Vero layout I created yesterday with your latest beta release, I'm finding this release much easier to use, one question, does this release still feature the transparency control?.... :hmmm:
BK Butler Tube Driver Layout
bancika
Post by bancika »
it should open files from the previous version without problems. Is there anything suspicious in the log (take the most recent file from log directory). If you can't read it post it here and I'll take a look.
DrNomis. Yes, double click a component and use the slider to change transparency. Now you can do it to different types of components at the same time
Post by DrNomis »
bancika wrote:it should open files from the previous version without problems. Is there anything suspicious in the log (take the most recent file from log directory). If you can't read it post it here and I'll take a look.
Aha....cheers Bancika, I'm really liking the latest beta btw..... :thumbsup
PerS
Fender Blues Jr
Hony Bee clone
BYOC Mighty Mouse
Post by PerS »
Hi Bancika
I have zip'ed a fil with all the log's and screen dumps for you and also supplied the drawing file from the old version (both in diy-format and as a pdf...) - http://dl.dropbox.com/u/26726734/Log%20report.zip. The screen dumps are in pdf-format and there is some notes/comments supplied. Hope it helps.
For me its no big deal if it's not possible to import old versions. Just for your info and and in case there is someone else that whant this feature.
Worked a bit more with the new version and I must say I liked it - the layout, how it works, the interaction... realy neet. I did run into another strange thing, it's documented in the zip, but I could not reproduce it a second time. It could actualy be my PC doing something. Happens on PC I've been told.
Again realy great job and thanks for shairing this with us. :thumbsup
bancika
Post by bancika »
Oh, I thought you meant 3.0.8 as the previous version. This file is saved with older 2.x. Currently import is not supported from v2 (it is partially from v1), but I'm working on that.
As for the other issue, it looks like you have selected "Outline mode" which only draws component outline.
Bane
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Just tried the latest version. Excellent! :thumbsup
PerS
Fender Blues Jr
Hony Bee clone
BYOC Mighty Mouse
Post by PerS »
:slap: Oh no, the human misstake again... :lol:
As I said, no big deal for me. Thanks for the quick replay
Take care //Per
Cub
Has thanked: 97 times
Been thanked: 114 times
Post by Cub »
I just made a layout of the Omega Booster with 3.0.9 beta, marvellous program ! :applause:
viewtopic.php?f=75&t=14143
bancika
Post by bancika »
looks great, glad you like it :thumbsup
I'm working on preparation that will allow porting to other platforms. Android will be the next one to tackle. On the other hand I have a bunch of new components to add :hmmm:
if I'm having a problem getting it to run, would the java thing be the most likely culprit? v2 works fine.
bancika
Post by bancika »
what's the problem?
Post by DrNomis »
RnFR wrote:if I'm having a problem getting it to run, would the java thing be the most likely culprit? v2 works fine.
You could try installing the latest Java Runtime Environment files and see if that fixes things, I decided to bypass things and installed the JRE files first, then installed the latest DIYLC beta, it worked properly right off the bat.... :thumbsup
lasermonkey
Has thanked: 48 times
Been thanked: 16 times
Post by lasermonkey »
Hi, I'm trying to run the latest version of DIYLC from my Mac, but unfortunately, the program crashes constantly.
CodeMonk
Has thanked: 13 times
Been thanked: 54 times
Post by CodeMonk »
DrNomis wrote:Hi Bancika, here's a Vero layout I created yesterday with your latest beta release, I'm finding this release much easier to use, one question, does this release still feature the transparency control?.... :hmmm:
Work-around for the transparency feature:
Lock Layers menu, select Component.
How are you getting the components/values displayed?
I didn't see any options for that.
