Page 17 of 20
Re: Do-It-Yourself Layout Creator [freeware] -- Updates log
Posted: 13 Sep 2012, 14:11
by Dr Tony Balls
A HA....then maybe ive uncovered a Mac bug. My left and right clicks do the exact same thing. No menu pop-up for a left click, it just selects or deselects the component as usual. If I double right click it opens up the edit window like a normal double left click.
Posted: 13 Sep 2012, 14:41
by bancika
I heard that mouse clicks are different on some macs and some mice....will take a look.
As far as templates go, there are two kinds: layout templates (which are just DIY files) and component templates which are specific flavors of component. They are saved from the context menu.
Posted: 13 Sep 2012, 15:11
by Dr Tony Balls
Ahhh yeah Im looking for the component templates. The layout template works just fine.
Posted: 17 Sep 2012, 14:15
by bancika
fixed context menu for mac in 3.16...
Posted: 17 Sep 2012, 15:17
by Dr Tony Balls
bancika wrote:fixed context menu for mac in 3.16...
FUCK YES. :applause:
Posted: 18 Sep 2012, 10:08
by bancika
Btw, can someone verify that OSX distribution works fine on their machines? I tried on one and it was fine.
http://code.google.com/p/diy-layout-cre ... loads/list
Just download one that says OSX and run
Posted: 18 Sep 2012, 10:31
by deafbutpicky
@bancika
I don't know what you did, but you did it right :D
Templates and transparency bug are now fixed in version 3.16 under Linux. thanks :applause:
Posted: 18 Sep 2012, 12:15
by bancika
since there's confusion around component templates, I added an instructional video
Posted: 18 Sep 2012, 13:53
by Dr Tony Balls
bancika wrote:Btw, can someone verify that OSX distribution works fine on their machines? I tried on one and it was fine.
I get an error saying:
"DIYLC" is damaged and cant be opened. You should move it to the trash.
Posted: 18 Sep 2012, 15:23
by bancika
try this:
Go to System Preferences, Security and Privacy and under 'Allow applications downloaded from', select anywhere or add my site
Posted: 18 Sep 2012, 16:11
by Dr Tony Balls
nah, its not that. I usually get that kind of message when I DL a new version from you and I approve your site when opening the .jar. This is different. Here's the message:
and from an apple support site I found this:
Code: Select all
"Damaged" app. – The app has been altered by something other than the developer. This message will appear no matter the Gatekeeper option chosen.
"App name" is damaged and can't be opened. You should move it to the Trash.
Safari downloaded this file on Date & Time from URL.
"gatekeeper" is the foreign app control, apparently.
Posted: 18 Sep 2012, 16:13
by Dr Tony Balls
dang, nevermind. it appears to be a mountain lion bug. If I select allow apps from anywhere then it opens fine!
Posted: 20 Sep 2012, 20:36
by CodeMonk
Rotating toggle switches: YES
Transistors with offset pins: YES
And.....
Layers property : YES, YES, YES, YES, YES, YES, YES
Love ya for that bancika
Posted: 24 Sep 2012, 17:14
by sinner
Downloaded new 3.17 just 20 minutes ago (8 minutes after release ;) ) and the component templates still not working with me. I've tried on Windows 7 Starter/7 pro/vista
Still nothing
I don't know what I do wrong
Posted: 24 Sep 2012, 21:00
by bancika
can someone try the latest version, especially the OSX builld. I added screen menu support.
@sinner, I have to ask. are you sure you're doing it right? Did you see the video tutorial?
Does simple config change work. Try opening the app, changing one property in Config menu (from unchecked to checked) and restarting. It should save your config change. Templates are saved to the same location, so they should work the same as config.
tnx
Posted: 24 Sep 2012, 22:54
by sinner
bancika wrote:can someone try the latest version, especially the OSX builld. I added screen menu support.
tnx
I have tried all possible ways. Also saved the project file with resistor (or any other) templates I did before closing the soft. I was closing the soft in two different ways - by hitting the red button on top right corner, as well as by exit button in DIYLC. And nothing. Still cant remember any of my settings. It's getting open just like the "new version" with no user settings at all. It starts with project templates (even if I disabled "show this dialog after starts up"), no any of the component templates I created, also - always the very first thing I do with new DIYLC version is I'm switching off Sticky Points in Config menu, and also this comes back with every new DIYLC startup
Also, yeah Bane, I've seen the video ;)
Posted: 25 Sep 2012, 09:20
by bancika
sorry, had to ask :)
can you try the exact same scenario as I explained? Just one single config change, no messing with components, opening files, or anything. I want to rule out possibility of config being overwritten by mistake
tnx
Posted: 25 Sep 2012, 09:43
by sinner
bancika wrote:sorry, had to ask :)
tnx
No biggy, I feel like idiot anyway ;) AFAIK only I have this problem
I don't know how I should do this config change, can you explain?
Posted: 25 Sep 2012, 10:38
by bancika
just click on "Sticky points" or any other config item in the main menu. It should flip from checked to unchecked (or the other way round). That should be saved to config file automatically and be restored when you restart
tnx
Posted: 25 Sep 2012, 12:54
by Dr Tony Balls
Tried it but the only palette im getting is the "recently used" one.
