Do-It-Yourself Layout Creator [open-source]  [link]
bancika
Has thanked: 16 times
Been thanked: 88 times
Post by bancika »
thanks, I found what I f'd up. will be fixed in 3.18
bancika
Post by bancika »
Dr Tony, can you try the latest 3.18? I don't have a mac to test, but it should work now.
tnx
Dr Tony Balls
Been thanked: 170 times
Post by Dr Tony Balls »
did you zip it in a different way than before? Im having problems unzipping it.
bancika
Post by bancika »
looks like the zip got corrupted somehow. I reuploaded
Dr Tony Balls
Nah, i still only get the "recently used" items.
Let me ask you this, id the new OSX version all inclusive or does it need a separate folder full of shapes etc like the regular version had? I've deleted all older version of DIYLC and im just using the OSX version.
bancika
Post by bancika »
it's all inclusive. Damn, I'll have to debug again and figure out a problem :( How bout the multi-platform version, does that work on OSX?
Until then 3.16 is the last version that works on OSX.
Dr Tony Balls
Yeah the multiplatform version works great. Using the .jar file, too. It doesnt transfer my component templates, though. Is there a way to do that?
bancika
Post by bancika »
you mean transfer between the old and new version? If so, just copy config.xml from the old installation dir to the new one.
Is it possible to add the feature to place the text field in reverse (inverted)?
bancika
Post by bancika »
for PCB artwork?
bancika wrote:for PCB artwork?
Yes Sir :)
bancika
Post by bancika »
ah ok, that would require more changes because regular text doesn't get exported to toner transfer output. This would probably go as a new component. Can you file a request on diylc.org? That way I won't forget and you'll be notified on email when it's resolved.
that's generally preferred way of handling requests, everybody, please file them, it's easier for everyone :)
tnx
bancika
Post by bancika »
Dr Tony, could you please check out 3.19? I hope I have fixed the dedicated mac build now.
Also, sinner, you got your mirrored text for PCB :)
Dr Tony Balls
Seems to work well!!! Thanks Bane.
bancika
Post by bancika »
fixed the problem with saving component templates and config. Grab the latest version :thumbsup
Now it works great :) I didn't want to excruciate you with this, as I know you have an social life too ;) And I could live with that :)
You're one and only Bane :thumbsup
bancika
Post by bancika »
Ok, I need to take a break, too much stuff done in the last couple of days :horsey:
tra
Post by tra »
Any way to get this running on Android? Just got a Galaxy Note 2 with a screen big enough that this would be awesome.
bancika
Post by bancika »
I'm afraid not. Java for android is not the same, so I'd have to rewrite most of the code to retrofit it to Android.
I planned to do it, even started prep work, but don't have enough time to finish.
tra
Post by tra »
bancika wrote:I'm afraid not. Java for android is not the same, so I'd have to rewrite most of the code to retrofit it to Android.
I really appreciate the reply. I just started using DIYLC a few weeks ago after a couple years of farting around with Eagle. I really dig it! Much easier to whip together a layout when using on board pots since it is using pad per hole measurements.
My desktop is connected to a monitor and is also used by my Roku. When the wife or kid is watching a show I can't use my desktop. In the meantime, I think I'll use Air Display and a wireless keyboard/mouse combo. It's when I'm away from home that having a mobile version would be cool, but now that Windows 8 is out this might be a reality sooner than later.
Really cool software. I plan on donating once my eBay funds clear Paypal's hold period. :horsey:
