Do-It-Yourself Layout Creator [open-source]  [link]
JOHNO
Has thanked: 47 times
Been thanked: 53 times
Post by JOHNO »
What is java? :scratch:
Electric Warrior
Has thanked: 23 times
Been thanked: 104 times
Post by Electric Warrior »
bancika
Has thanked: 16 times
Been thanked: 88 times
Post by bancika »
jstbrowsin wrote:thanks. . . maybe in future best to say intel only :hmmm:
:slap: its all good guess I have to run dumb windoze til I get an intel :shock:
oh well :whappen:
can you get some sort of linux?
jstbrowsin
Grease Monkey
Has thanked: 65 times
Post by jstbrowsin »
possibly I know there is a Ubuntu Linux out there but never used it or Linux for that matter. I have heard that linux and mac are similar but I guess I'll google that later. Why do you ask? Is it important that I get it to be able to run this program?
There is also a 3rd party Java for mac called soylatte so I'll be looking into this also when I get some spare time. :roll:
bancika
Post by bancika »
You said you hate windows, so I mentioned linux as a free alternative. Ubutnu is as easy to use as windows and maybe even easier to install.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
jstbrowsin wrote:possibly I know there is a Ubuntu Linux out there but never used it or Linux for that matter. I have heard that linux and mac are similar but I guess I'll google that later. Why do you ask? Is it important that I get it to be able to run this program?
Canonical,the company that makes the Ubuntu Operating System,just recently released Ubuntu 10.10,you can download the disk .iso file from their website,it is only about 700Mb in size.... :)
Atomsk
my favorite amplifier: Acoustic B10
Post by Atomsk »
Excellent work so far.
I 'd like to request the ability to differentiate between jumpers on the bottom of the board vs the top.
Generally, when building on perfboard, I try to put components and jumpers on the top of the board running "north-south" and jumpers on the bottom running "east-west", but when the board gets crowded, I wind up breaking the rules sometimes.
Having different colors for the topside and underside jumpers can make the layout clearer, and avoid any unintentional crossed circuits.
Will the final version provide the user with the ability to create his own component images?
Gibson EB Zero!
1961 Model!
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
I like the new version, but in general it could be useful to check, if the number of clicks that is needed to reach a function can be reduced.
bancika
Post by bancika »
roseblood11 wrote:I like the new version, but in general it could be useful to check, if the number of clicks that is needed to reach a function can be reduced.
what functionalities could be optimized?
Atomsk wrote: Will the final version provide the user with the ability to create his own component images?
you mean create his own components? If so, it's possible even now, but API still changes so it's best to wait. Here's the guide http://code.google.com/p/diy-layout-cre ... mponentAPI
bancika
Post by bancika »
Version 3.0.4 is released.
If you're running older version 3.0.x, you should be able to see the yellow light bulb in the bottom left corner indicating that updates are available. Click on it gives the list of changes and download link. From now on, I'll keep that feed updated.
After I released 3.0.4, I found that editing numerical values is messed up. I'll fix that in the next round, but there should be enough good stuff in this version to make it worth checking out.
http://code.google.com/p/diy-layout-cre ... p&can=2&q=
Bane
Post by DrNomis »
I just downloaded the file and took it for a test run,it's looking good Bancika..... :)
bancika
Post by bancika »
cool, glad you like it
Post by DrNomis »
bancika wrote:cool, glad you like it
Is it the finished version,or are you still doing developmental work on it,Bancika?.... :)
What I like most about this new version is that I no longer have to use the command window to launch it,all I have to do now is right-click on the exe file,and click on run,and it launches,simple as that,I'm running Windows 7 Home Premium 32Bit edition on my PC,and DIYLC works fine..... :)
One question,is there a way to expand the range of component symbols?..... :)
Cheers Bancika.... :thumbsup
bancika
Post by bancika »
it's called alpha, so there will be a lot of more to be done :)
I'll start expanding component set soon, did you have any particular components in mind?
Anyone can add their own components, but you need to know java.
Post by DrNomis »
bancika wrote:it's called alpha, so there will be a lot of more to be done :)
No worries.... :)
You already have symbols for ICs,Diodes,Capacitors,and Resistors,so I think maybe symbols for bipolar transistors,voltage regulators(eg:LM7815,LM7915 etc),Leds,trimpots,PCB pins(for off-board connections),and any of the other standard electronic components too,could be added,maybe some other members could add their ideas on what other component symbols could be added.... :hmmm:
It would be cool to have some way of generating a .pdf of a finished layout created by DIYLC as well,not sure how feasible that is.... :)
Atomsk
Post by Atomsk »
Ahh yes, "R"ing "TFM" is always a good idea. :P
Gibson EB Zero!
1961 Model!
bancika
Post by bancika »
3.0.5 is out and it's now called beta :)
Post by DrNomis »
bancika wrote:3.0.5 is out and it's now called beta :)
Wicked!!!!... :thumbsup
Electric Warrior
awesome! love the resistor color bands (though it's still buggy, 47k comes out as green, purple orange instead of yellow purple orange).
As soon as I start working with text it crashes regularly. For some purposes a bolder font would be useful.
bancika
Post by bancika »
can you send me the logs (from log directory) to investigate the crash.
tnx
