Do-It-Yourself Layout Creator [open-source] [link]
- bancika
shift+mouse has been replaced with ctrl+mouse. I reckon this will be used more often than toggle snap to grid, so I assigned it to ctrl (which is easier to access IMO).
Send to back/front issue is fixed and will be released in few days.
As for the scale, yes, it occurred to me that it's not intuitive to leave just the slider. I'll do something about it.
- sinner
- Has thanked: 1031 times
- Been thanked: 907 times
I was thinking about ctrl when typing shift to be honest. Still doesn't working, at least with me
Thanks bro
Thanks bro
- sinner
Dear Bancika, since I'm making turretboard layouts mostly can you do some blank boards for me, and couple other guys like I?
Below one of my layouts drawed with your tool
- bancika
Where do you get small turret boards like that? What are the specs for those?
Btw, what used to be ctrl will be shift in the new version
this could be a limitation of my pc i suppose - but the u for microfarads seems to be missing on electrolytic caps when exported to pdf....
and +1 for tag boards!
cheers man this is awesome that you put this software together
Mark
Mark
- sinner
bancika wrote:Where do you get small turret boards like that? What are the specs for those?
Btw, what used to be ctrl will be shift in the new version![]()
Ebay
Big request. Don't put the ctrl+x function in new version
- bancika
You're covered there, in the v3 ctrl+x is assigned to standard cut to clipboard action, I don't know what possessed me to assign it to exit in the v2
- sinner
I was trowing around a lot of fcuk's and siht's because of itbancika wrote:You're covered there, in the v3 ctrl+x is assigned to standard cut to clipboard action, I don't know what possessed me to assign it to exit in the v2
- bancika
Hi all,
I'm uploading version 3.0.7, it adds some features that should improve usability. To turn them off and on, use Config menu option.
For full change log just click on the lightbulb icon in older versions, it should bring up everything added in the meantime.
- timbo_93631
- my favorite amplifier: Low wattage SE amps
- Completed builds: Many many many true bypass and voicing mods on wahs.
A few BYOC kits and DS-1 mods and eventual murder then rebirth into an actually useful pedal, Bad Stone clone, various Rangemasters/SilconMasterBlaster, The worlds greatest gutted GCB-95 volume pedal conversion with various switching options for controlling amps. Repaired many tube amps, scratchbuilt Marshall 18 watt clone and Supro 1616t rebuild. Delays, fuzz, dirt, every Madbean project I could afford. I even manage to find time to make babies with my wife too! - Location: Fresno, Ca
- Has thanked: 14 times
- Been thanked: 33 times
Just did my first layout using DIYLC. Great software, makes my layouts I used to do with MS Paint look like total junk! A few things that would help/bugs I found:
1. When using the image import function under the misc tab the program sometimes shuts down when I double click the image to edit it.
2. Program also shut down when I used Ctrl-V for pasting
3. A "send to front" and send to back" option would be helpful along with the move up - move back already available.
4. Being able to have an extra control point to bend the leads of a component would also be helpful when doing layouts on a turret board. Look at how I used jumpers on the cathode bypass caps in my layout below to make the parallel connections.
Most of all, THANKS BANCIKA!!!!!!!!!!!!!
"I wish to be in the situation of non killing my balls bills, and life surprises." -Sinner
"Everyone gets their shorts in a twist over who polished the fenders. No one cares about who designed the engine..." -DougH
- bancika
Thanks for comments, appreciate it!
As for the crash, can you try two things:
* increase available memory. If you have more than 2GB of ram, open diylc.l4j.ini and change it to look like this (you can use even more than 2048m=2gb if you have more
) -Xms2048m -Xmx2048m
* when you see the blue bar in the bottom right corner to go over a half, click it to run the garbage collector and free some memory.
Let me know if that helps.
I'll try to implement the other two, they are filed under http://code.google.com/p/diy-layout-cre ... tail?id=46
Bane
Bane
- bancika
They are exported to scale, that's why it's small. I'll increase resolution for PNG. As for PDF, we shouldn't change it because you want your PDF to be in scale when printing traces and similar stuff. PDF is in vector format so you can zoom it in as much as you want.
Thanks man! I'll look forward to that change.bancika wrote:They are exported to scale, that's why it's small. I'll increase resolution for PNG. As for PDF, we shouldn't change it because you want your PDF to be in scale when printing traces and similar stuff. PDF is in vector format so you can zoom it in as much as you want.
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
Hi Bancika,
I'm just in the process of making a Strip/Veroboard layout in the latest version of DIY Layout Creator, and I've hit a bit of a snag, everytime I go to place a passive component, resistor/capacitor/diode, etc on the board, I can't seem to resize the component so it will fit where I want to place it, it seems to be stuck on one size, what could be causing that?....
- bancika
did you happen to use the templates? I noticed that templates in the last version are not in scale. If so, just start with a blank project, copy-past all components from the new one except for the board and then add a new board.
I'll fix them for the next one.
- DrNomis
bancika wrote:did you happen to use the templates? I noticed that templates in the last version are not in scale. If so, just start with a blank project, copy-past all components from the new one except for the board and then add a new board.
Actually, no I didn't Bancika, I started from a blank screen, then clicked on the Stripboard button and dragged it to the size I needed, I'll try using a template and see if that sorts it out mate, I'm running version 3.0.7 on my PC....
Other than that I'm really liking the new version of DIY Layout Creator, one question, what happened to the transparency control?, was it something that had to be omitted for some reason?....
Cheers Bancika....
- bancika
if you haven't used templates, don't
they don't work good in the latest version.
when you say "I can't seem to resize the component so it will fit where I want to place it" does it mean that holes on the board do not align with component end points. Maybe you used amp style perfboard? It requires different grid spacing settings and doesn't work well with pedal-friendly 0.1".
as for transparency, it's still there. Just double click on a component and play with the slider. I haven't changed anything there for a while.
- DrNomis
bancika wrote:if you haven't used templates, don'tthey don't work good in the latest version.
In an earlier version of DIY Layout Creator that I've tried, when you place a component on the blank Veroboard, such as a resistor, you click on one hole and then drag the mouse cursor to the other hole, the component automatically resizes itself so that the component end points align with the hole positions, this doesn't seem to happen in the current version, I'm deffinitely using the Veroboard 0.1 inch spacing rather than the Amp perfboard, I should see if I can generate some screenshots so you can see exactly what's going on, also in the current version, I've noticed it seems to insist on standing resistors "on-end" rather than laying them flat on the board for component lead spacing greater than three holes wide....
Just had a thought, could this have something to do with my Java files?, I had to install Java Runtime Environment 6 before the software would launch properly, could they have become slightly corrupted by a faulty install?
I'll try and generate a few screenshots for you this week, so you can see what's going on Bancika...
- bancika
Oh I see, you always end up with standing resistors? Just double click on resistor body and make it smaller (length and width). Also, check those boxes on the right side of length and width boxes to make those values default for resistors. It automatically turns into vertical mode when pin spacing is less than resistor length.
