Seymour Duncan - Tweak Fuzz  [schematic]
Here is the:
Seymour Duncan Tweak Fuzz schematic
enjoy,
lynessmy
Post by lynessmy »
How are them compared? The link doesn't work...
BeAR
Post by BeAR »
Thanks to analogguru, I just built this stomp box. Schematic is spot on and sounds killer too!
Hope these help others. The ceramic on the bottom of the board just parallels up the 22pf on the top of the board as I didnt have a 47pf lying around.
BeAR
Post by BeAR »
Just another quick update if anyone cares, Ive been playing around with the 2 transistors in the tweak fuzz and Ive found a better combination . Q1 is now a BC550 and Q2 is a BS170. This gives a tighter more focussed fuzz without the wooly bottom end when the tweak knob is wound arount to the 2.2uf cap.
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
A BS170? You replaced a bipolar transistor with a switching MOSFET??
flood
Post by flood »
marshmellow wrote:A BS170? You replaced a bipolar transistor with a switching MOSFET??
:scratch: +1
holy p-n junctions, batman!
lynessmy
Post by lynessmy »
What a nice PCB from BEar. I gonna make this PCB.
In fact, I had drawn one and tried on the weekend. But it doesn't work.
With the audio probe, i found that there are no signal passing thru the selectable CAP, no matter in which position.
Can anyone help me to understand what went wrong? I didn't pop in the 1M pull down resistor.
BeAR
Post by BeAR »
Yeah I know, strange but it works a treat. There is a discussion in the Workbench section about it. Some fets seem to bias just right as a direct replacement. As I said in that post, it shouldnt work, but it sounds better than any other option Ive tried.
iggy23
Post by iggy23 »
has somebody a vero layout???? :roll:
B3ar
Has thanked: 30 times
Post by B3ar »
I got a good deal on a new Tweak Fuzz and am quite pleased with the implementation of SMD -- there are through-holes next to the SMD transistors and resistors, while the caps are already through-hole. Cheap to manufacture, easy to mod -- thanks, guys!
Folks mention that since it's a FF, mod accordingly, and apparently there's a popular easy variant on the Roger Mayer "volume" mods out there. (Remove R5, change R4 to 8k2.) I'm going to try some of the standard value tweaks over on R.G.'s Geofex page, especially those that are just resistor changes.
But I wanted to ask whether anyone has sub'ed out the stock SMD transistors, and whether it was particularly life changing. This is my first FF and I'm not unhappy with the base tone, but I want to be sure I'm not missing the boat.
holgar
Post by holgar »
Thanx for the shem,
this Fuzz Face got the right name, because it is so easy to tweak.
For some more volume I lifted R4 to 1K. For biasing Q2 I took 10K at R5 (4,8V).
Instead of the useles C5 120n I took a Mullard 0,022uF, because I was missing a position 2,5 on the Tweak knob.
Of course the Mullard mojo oozes now through the whole circuit ;-)
biglouis
Post by biglouis »
Does anyone have the schematic?
The analogguru link is offline.
LooseCannon
Post by LooseCannon »
Same question here.
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
here it is
LooseCannon
stilwel
Post by stilwel »
FYI....I believe Q1 and Q2 are mislabeled in the schematic. If you trace out the circuit, Q2 on the PCB is actually the input buffer transistor.
I have 2 Tweak Fuzz pedals here, both have Rev A PCBs. Maybe they changed it on a later revision?
Anyway, I'm in the process of looking for some BC183 BC183C transistors for this beastie and discovered this tonight...thought I'd share.
ljn
my favorite amplifier: Sears 125 xl, Kasino U100-P
Completed builds: Fuzzrite (Si and Ge versions) , univibe, companion fuzz, fuzz face(si version), FY-6 super fuzz, FZ-1S, Scrambler, Tone Bender MkI (nearly complete). I have modded my vox v847,Seymour Duncan tweak fuzz, my bass and my guitar ( slightly).
Been thanked: 7 times
Post by ljn »
I just tried the resistor values suggested by holgar on my tweak fuzz. It sounds better than ever.
