Neo-Classic 741 Overdrive (Gray 250 Clone) PCB Transfer
snmavronis
Completed builds: My DIY stompbox builds:
- Neo-Classic 741 Overdrive (gray spec 250 Overdrive clone)
- MXR Distortion+ (diy replica pcb replacement 1980 block logo)
- Neo-Classic 3080 Compressor (script spec Dyna Comp clone)
Been thanked: 14 times
Post by snmavronis »
If anyone who can etch their own PCB wants to try this project to build a verified working Neo-Classic 741 Overdrive (gray spec 250) for yourself, I posted the same PCB transfer that I used at 300dpi in Adobe Acrobat format here:
http://sites.google.com/site/snmavronis ... 1overdrive
Look under the PCB Transfer section for printing instructions and the download link. Even though I like to use PCB soldered pots for mounting purposes, you don't have to - just attach pot lug wires instead. But if you do like PCB mounted pots too, I recommend using a Hammond 1590B enclosure so my 1.2" shaft spacing fits the same as in my build picture. Just leave enough room from the top for the PCB inside! Panel cover art not included...
Have fun and enjoy.
Steve
Guitar > Boss NS2 Noise Suppressor > NS2 Send > MXR Custom Comp > Neo-Classic 741 Overdrive > NS2 Return/Output > VHT Special 6 Ultra Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
