Musitronics - Mutron Micro V  [schematic]
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
it seems like there is no thread about this little filter.......since I am obsesed with old Mutron and EH stuff......here is some info and links
http://www.pisotones.com/MuTron_Micro-V ... icro-V.htm
http://www.effectsdatabase.com/model/mu ... ron/micro5
Boris
not sure if they are related or not, but it sounds very similar to the EH Dr. Q.
borislavgajic
RnFR wrote:not sure if they are related or not, but it sounds very similar to the EH Dr. Q.
Dr.Q is OP amp based(like morley wahs) but instead of LDR have transistor to ground as controlling device.......
Mutron have OTA
:thumbsup they are close but different
Boris
borislavgajic
and nice Japanese page with guts
http://www.tcgakki.com/items02/tc024073.html#photo
Boris
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Does this pedal work with bass, or how could it be modded?
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
just a friendy FYI
OTA filter pedals:
FSH-1 and clones
DOD FX25/25B
Agent 00Funk
LDR Filters
Mutron
Q-Tron / Plus
MeatBall
Cd4066
MXR Envelope Filter
Emma Discumbobulator
OpAMP
BassBalls
Thats all I remeber at this time.
Skyline FX 2013
candidate
Has thanked: 72 times
Post by candidate »
borislavgajic wrote:and nice Japanese page with guts
Boris
are those house numbers on the IC's ?
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
This is verified for anyone wanting a quick vero build
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
Great work as always, IvIark.
Here's a schematic for a version using both sides of a 13700 instead of the original 3080: I've breadboarded it and it sounds pretty good. Might do a vero for it when get a chance -
Govmnt_Lacky
Post by Govmnt_Lacky »
So... no issues with the single feed to multiple inputs of the 13700?
Essentially, if the OTAs inside are not dead on with each other, does it or will it cause some kind of problems with the outputs?
Nocentelli
Well, it worked fine for me on the breadboard, although I know deadastronaut over on DIYSB couldn't get his to work. I couldn't comment on the possible causes of the problem. There are plenty of filter circuits that control the sweep via pin 1+16 together. This version of the circuit just attracted me because I have a handful of 13700s but no CA3080s.
I'm still planning to put together an MS20-style super resonant LPF triggered by the MicroV envelope section: It's nice and simple with just half a dual opamp and the pnp transistor and works really well.... maybe one day I'll have time.
PCBGuitarMan
Post by PCBGuitarMan »
Here is a verified schematic and the board I made with it, in this build I used LM13700 instead of CA3080:
I've some PCBs if you are interested in getting one of these to play around with :shred:
https://pcbguitarmania.com/product/vutron-v/
I'm here to help you building great pedals.
Check out our boutique effects PCBs at:
