There's another way to generate 250V DC,all you need is a 12V AC plugpack,a 240VAC to 12.6V AC@150mA transformer,1X DC socket,1X DC Plug to fit socket,4X 1N4007 Power Diodes,and a 47uF/450V DC capacitor....
Method:
First,solder the DC Plug onto the 12V AC Plugpack's lead,next,build up the circuit shown in the schematic below,solder the 240V AC primary leads of the 240VAC to 12.6V @150mA Transformer,to the AC input of the bridge rectifier,then solder the 12.6VAC @150mA secondary leads to the DC socket,insert the DC Plug into it's socket,plug the plugpack into a wall socket and switch on,you should see about 240V-300V DC across the 47uF/450V DC Capacitor.
Yes,what we are doing is using the transformer backwards,it steps up and converts 12V AC to 240V-300V DC
