DOD - 210 FET Preamp  [schematic]
Postby marmaliser » 01 Feb 2011, 10:21
Did a search and can't see anything specific for this
Here are some Pics
Discofreq please feel free to use these on the effects database
For this message the author marmaliser has received thanks: 2
modman (14 Apr 2019, 18:52), RnFR (01 Feb 2011, 17:40)
marmaliser
Has thanked: 56 times
Have thanks: 48 times
Re: DOD FET Preamp
Postby marmaliser » 01 Feb 2011, 10:24
Judging by the pot date this is from around 1979. I will do a shot of the other side of the board when I get home.
marmaliser
Re: DOD FET Preamp
Postby Greenmachine » 01 Feb 2011, 19:40
I built a clone of one of these. I used to call it a dirty clean boost. Not as high gain as the Crackle-Not-Okay I recently built, which is loud-as-all-get-out ... all I have to do is switch it on and I'm boosted, volume at zero.
Greenmachine
Has thanked: 102 times
Have thanks: 19 times
Re: DOD FET Preamp
Postby marmaliser » 01 Feb 2011, 21:32
Just flipped the board over and it has 210 written so this is just the FetPreamp 210 in an earlier box
marmaliser
Re: DOD FET Preamp
marmaliser
dod fet preamp 210 grey
Postby jazzmguitar » 27 Jul 2015, 14:09
I have a dod fet preamp 210 grey one knob . Years ago I added a led switch and power supply. All works apart from when the power supply touches the metal case it then cuts off and power doesn't go to the pedal . Any ideas how to rewire it correctly? I tried to insulate around the power supply which didn't work great. Hope someone can help. Tried to upload photo but it 4.5mb limit is 1mb..
jazzmguitar
Re: dod fet preamp 210 grey
Postby Duckman » 28 Jul 2015, 02:00
Reduce pic size? :secret:
Duckman
Has thanked: 369 times
Have thanks: 144 times
Postby jazzmguitar » 28 Jul 2015, 13:52
Hi, manged to make photos smaller hope someone can help....
For this message the author jazzmguitar has received thanks:
Duckman (31 Jul 2015, 23:40)
jazzmguitar
Postby jazzmguitar » 28 Jul 2015, 13:56
This might help lead to the answer?
jazzmguitar
Postby Blitz Krieg » 29 Jul 2015, 06:27
get a plastic power jack?
Blitz Krieg
Has thanked: 577 times
Have thanks: 4 times
Re: DOD - 210 FET Preamp  [schematic]
Postby modman » 30 Jul 2015, 17:28
dc jack is probably grounding on the case?
did you connect the 9v to that pole on the dc jack?
if that's how your power source demands it, you should get a fully insulated jack.
schematic found online...
Has thanked: 3563 times
Have thanks: 692 times
Postby jazzmguitar » 31 Jul 2015, 23:25
Many thanks for your replies. Sorry I'm not very good at this when you say did I conect 9v to pole on jack I'm unsure what this means. Do you mean were does the positive go from power jack go? I ve try to show this in the photos of the board... they go to second hole on the board please excuse poor soldering skills. Please see attached is this the part I need i e a insulated power jack ...thanks phil
jazzmguitar
Postby modman » 01 Aug 2015, 13:35
Please don't snapshot & upload 0.5MB images that you can link too.
Get a digital multimeter and check for continuity: is the metal part that's touching the case connected to red/black/white wires?
If white is 9V+ as is the red one, they should be connected together. But the pictures don't tell anything really, we cannot tell what is connected to what.
Debugging = testing the circuit, it cannot be done by pictures alone.
if you have no skills and no multimeter, stop trying.
Postby jazzmguitar » 01 Aug 2015, 14:03
Hi I have a multimeter and willingness to try. I can confirm the 9v + from power supply goes where originaly the 9v+ from the battery went as shown in the schmatics. The 9v+ is not conected to the case until the power supply javk is inserted this then completes a circuit and the plus side is conrcted to the case as tested by the multi meter. I assuming this is because the power jack is metal and need a plastic one instead? Thanks
jazzmguitar
Postby jazzmguitar » 08 Aug 2015, 11:43
Update fitted plastic power jack and all works perfectly . Thanks for your help this is a underrated pedal I shall use it over the next few gigs and report back.
jazzmguitar
Users browsing this forum: Boba7, Gypsy Roadie and 8 guests
